The following code compiles fine with -fast but not with -fastsse on a Pentium 3 machine.
$ cat spill2.f90
MODULE SPILL
IMPLICIT NONE
INTEGER, PARAMETER :: N = 14
REAL, SAVE :: A(5*13,N), S(10,N), FRF(N)
REAL, SAVE :: C(0:200)
CONTAINS
SUBROUTINE T(K1, K2, CLH, FAC, F, S1, S2, TG, LT)
INTEGER, INTENT(IN) :: K1, K2
INTEGER, INTENT(IN) :: LT
REAL, DIMENSION(:,:), INTENT(INOUT) :: TG
REAL, DIMENSION(:), INTENT(IN) :: CLH, FAC, F, S1, S2
INTEGER, PARAMETER :: N1 = 8
REAL, DIMENSION(K1:K2) :: F0, F1, F2, F3
INTEGER :: J, IFP, I, IND0, IND1, INDS
DO J = 1, LT
F3(J) = FAC(J) * C(IFP)
DO I = 1, N
TG(N1+I,J) = CLH(J) * (F0(J) * A(IND0,I) + &
F2(J) * A(IND0+1,I) + F1(J) * A(IND1,I) + &
F3(J) * A(IND1+1,I) + S1(J) * (S(INDS,I) + S2(J) * &
(S(INDS+1,I) - S(INDS,I))) + F(J) * FRF(I))
END DO
END DO
END SUBROUTINE T
END MODULE SPILL
$ pgf95 -c -fastsse spill2.f90
PGF90-W-0000-Internal compiler error. xr_getreg: no reg to spill 9 (spill2.f90: 22)
PGF90-W-0000-Internal compiler error. xmm_to_mem 0 (spill2.f90: 22)
0 inform, 2 warnings, 0 severes, 0 fatal for t
/tmp/pgf95o2xfQbMFPeZ4.s: Assembler messages:
/tmp/pgf95o2xfQbMFPeZ4.s:266: Error: bad register name `%xmm8'
/tmp/pgf95o2xfQbMFPeZ4.s:267: Error: bad register name `%xmm8'
/tmp/pgf95o2xfQbMFPeZ4.s:271: Error: bad register name `%xmm8'
/tmp/pgf95o2xfQbMFPeZ4.s:278: Error: bad register name `%xmm8'
$ pgf95 -V
pgf95 7.1-6 32-bit target on x86 Linux -tp piii
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2007, STMicroelectronics, Inc. All Rights Reserved.
Is this fixed in the current release, or is there a workaround, or is the fastsse flag just not a good idea on a Pentium 3?
