At the end of profiling with visual porfiler after execution of the program finishes I get the following error:
======== Error: CUDA profiling error.
==20424== Error: Internal profiling error 4087:35.
Program itself runs fine , cuda-memcheck doesn’t complain (though kernel instrumentation mode doesn’t seem to work)
Any info on what that error might mean and how to workaround it ?
Edit: I’m using latest sdk and latest drivers and windows10 64bit.
Update: I’m trying to isolate what function call is causing the problem and I discovered that it happens to choke on specific cuda calls, for instance, if don’t call cudaGetMemInfo function, then it goes further without an error until it complains about cudaCreateStream call (which I cannot workaround unfortunately).
Are able to profile other apps successfully?
Or you are getting same error for any app?
Can you profile the apps successfully if you run as an administrator?
I was able to identify the problem. When I simplified the program to a few cuda calls, in between those 2 lines with the original error message a new line appeared saying something about non-admin user access. Then I checked that the setting which enables profiling for non-admin users and discovered it was reset to disabled, probably by a windows or driver update.
Basically the actual problem was that I didn’t get a proper error message. It would be nice if nvprof would provide more context in addition to internal error code number.
Hi,I also have the same error in a docker container. I use cuda10.0, and when I use nvprof to analyze the TensorFlow example, its output is as follows.
==24928== Error: Internal profiling error 4055:34.
Is any detailed log where I can get?
This error code indicates that application needs to be recompiled nvcc version 9.0 or later. Can you please recheck after recompiling the application?
I got the same problem too, I got 4142:999. error code, and I can’t find any way to remove it, is there any documents contain code detail? or what’s the meaning of 4142:999.
Second number in the duplet is the CUPTI error code, which can be found in the header cupti_result.h shipped as part of the CUPTI SDK with the CUDA toolkit. Error code 999 stands for CUPTI_ERROR_UNKNOWN which makes it difficult to decipher what went wrong.
Few error codes for quick ref:
CUPTI_ERROR_CUDA_COMPILER_NOT_COMPATIBLE = 34
CUPTI_ERROR_INSUFFICIENT_PRIVILEGES = 35
CUPTI_ERROR_OLD_PROFILER_API_INITIALIZED = 36
CUPTI_ERROR_UNKNOWN = 999
