Jetson
• DeepStream Version
6.0
4.5.1
• TensorRT Version
8.0.1
bug
Run deepstream in docker (network mode host) and output an RTSP stream, this will also produce a udp stream. Find information about the stream using:
ffmpeg -i udp://224.224.255.255:5400 -vcodec copy -acodec copy -f null -
which outputs:
udp://224.224.255.255:5400: Invalid data found when processing input
This is the rtsp sink config I’m using:
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=2700000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
set below properties in case of RTSPStreaming
rtsp-port=8556
udp-port=5400
I can view packets in wireshark, or view a tcpdump of the outputted packets:
sudo tcpdump -i paneth2 -Q out | grep 5400
12:25:32.845697 IP kxm-3b1287.59434 > 224.224.255.255.5400: UDP, length 1400
12:25:32.853677 IP kxm-3b1287.59434 > 224.224.255.255.5400: UDP, length 614
but I can’t connect to the udp stream using vlc (udp://@224.224.255.255:5400)
The tcp unicast stream output @ rtsp://0.0.0.0:8556/ds-test works fine and I can view it in vlc
How can i fix this and view the multicasted udp stream?
