A moderator said “Isaac Sim requires an RTX GPU with at least 8GB VRAM” in this link Is an RTX 3060 enough to run Isaac Sim? Does it mean RTX 2060 with 12GB VRAM can run Isaac Sim? Looking forward to a reply, thank you!
Hi. Yes the RTX 2060 with 12GB VRAM should work but you may hit a performance limit. We recommend the RTX 2070 as a minimum. Please see 1. Isaac Sim Requirements — Omniverse Robotics documentation
Thank you for your reply!
