I read through the document for DeeStream SDK3.0, there is the Docker available for Tesla. Does anyone know or have used any docker that I can use on Xavier?
Thank you for any suggestion.
you do not need docker at Xavier to use Deepstream at Xavier as there is DeepStream version for Xavier. However some docker seems to work at Xavier, but that is kind of out of scope of use of the Deepstream at it.
I used Jetpack 4.1.1 directly on Xavier without a docker and seems to work smoothly, however on the host computer I have a docker installed which I configured manually with TensorRT 5.0.2 and Cuda 10 to be compatible with Xavier
