Is channel and spatial reliability implemented in VPI DCF Tracker?
I originally use OpenCV CSRT Tracker in my project, it tracks object fine even when the object is move fast. But it only utilizing CPU.
So a switched to use VPI DCF Tracker, which results a way better frame rate but the tracked box seems drifted when object or camera moves, which doesn’t happen on OpenCV CSRT.
I wonder are there significant difference between the implementation of those two trackers? Is channel and spatial reliability implemented in VPI DCF Tracker or there are other differences?
May I know which Jetson platform and the JetPack SW version?
Yes.
I’m using Jetson Orin Nano 8GB with JetPack 6.1 and VPI 3.1
For JetPack 6.1, the VPI version should be 3.2.
Please help to double-check.
You can find more info about the VPI DCF tracker in the below document.
https://docs.nvidia.com/vpi/algo_dcf_tracker.html
VPI implements a subset of the CSR-DCF paper. It doesn’t implement the discriminative scale-space tracking, hence not tracking object’s scale changes over time. Only the object’s position is tracked.
Hello, I’ve double-checked and it’s JetPack 6.0
By the way, when I run VPI example 19 with only bbox at frame 0 (all non-frame-0 bbox are removed from the txt file), the tracked boxes jitters and slides from target as the video (pedestrian.mp4) goes, which doesn’t happen in OpenCV CSRT.
As you mentioned above, although DSST is not implemented, the size of targets in pedestrian.mp4 doesn’t change, I think it’s probably not the cause.
The sample is used to demonstrate the usage only.
To get a better tracking quality, you will need some extra steps which are mentioned below:
https://docs.nvidia.com/vpi/sample_dcf_tracker.html
The sample implements a simplistic tracking pipeline using poor tracking quality. For production-grade tracking quality, you must implement proper object lifetime management and bounding box refinement stages in the code section named “Custom target update”.
