DRIVE OS Version: 6.0.10
I have a question about ImageMetaData.sensorExpInfo.exposureTime described in the following document:
Observations
- Using nvsipl_camera on Drive OS 6.0.10.0, I observed camera frames for several seconds and found that exposureTime had exactly the same value for every frame at 1 us resolution.
- This behavior suggests that the field may represent the exposure time configured on the sensor, rather than a measured per-frame value.
- However, when I performed the same observation on Drive OS 6.0.8.1, I saw fluctuations of approximately 100 us.
- Because of this difference, I am wondering whether the field might instead represent a measured exposure time for each frame.
Questions
- Does ImageMetaData.sensorExpInfo.exposureTime represent the measured exposure time, or the exposure time configured on the sensor?
- If it is a measured value, were there any known changes or improvements in measurement accuracy or stability between Drive OS 6.0.8.1 and Drive OS 6.0.10.0?
Related Question
I also have a similar question about dwImageMetaData.sensorStatistics.exposureDurationUs in the DriveWorks API.
Does this value represent a measured exposure duration, or a configured value?
