I want to load 19.05.0 dpdk with latest rdma in CentOS7.2.
I tried to load it, but it failed.
Is it possible to start dpdk using rdma, not OFED?
I think that rdma have bugs.
lspci info:
[root@SNIPER app]# lspci |grep Mella
3b:00.0 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5]
af:00.0 Ethernet controller: Mellanox Technologies MT27800 Family [ConnectX-5]
ifconfig info:
※ In using OFED, mellanox interface loaded in eth2 and eth3, but now it didn’t load.
[root@SNIPER app]# ifconfig -a
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.11.64 netmask 255.255.255.0 broadcast 10.0.11.255
inet6 fe80::20d:48ff:fe4e:8c1b prefixlen 64 scopeid 0x20
ether 00:0d:48:4e:8c:1b txqueuelen 1000 (Ethernet)
RX packets 234013 bytes 23926333 (22.8 MiB)
RX errors 0 dropped 10 overruns 0 frame 0
TX packets 6534 bytes 1410452 (1.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0x9c500000-9c5fffff
eth1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:0d:48:4e:8c:1c txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
device memory 0x9c200000-9c2fffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 0 (Local Loopback)
RX packets 324 bytes 18144 (17.7 KiB)
TX packets 324 bytes 18144 (17.7 KiB)
rdma library version info:
[root@SNIPER app]# rpm -qa |grep rdma
rdma-core-devel-17.2-3.el7.x86_64
rdma-core-17.2-3.el7.x86_64
librdmacm-17.2-3.el7.x86_64
lsmod info:
[root@SNIPER app]# lsmod
Module Size Used by
igb_uio 13476 0
xprtrdma 50777 0
sunrpc 300421 1 xprtrdma
ib_isert 55331 0
iscsi_target_mod 295398 1 ib_isert
ib_iser 52048 0
libiscsi 57233 1 ib_iser
scsi_transport_iscsi 99909 2 ib_iser,libiscsi
ib_srpt 52416 0
target_core_mod 371914 3 iscsi_target_mod,ib_srpt,ib_isert
ib_srp 47430 0
scsi_transport_srp 20725 1 ib_srp
scsi_tgt 20027 1 scsi_transport_srp
ib_ipoib 91475 0
rdma_ucm 22569 0
ib_ucm 22546 0
ib_uverbs 47183 2 ib_ucm,rdma_ucm
ib_umad 22129 0
rdma_cm 43697 4 xprtrdma,ib_iser,rdma_ucm,ib_isert
ib_cm 46821 5 rdma_cm,ib_srp,ib_ucm,ib_srpt,ib_ipoib
ib_sa 33950 5 rdma_cm,ib_cm,ib_srp,rdma_ucm,ib_ipoib
ib_mad 47817 4 ib_cm,ib_sa,ib_srpt,ib_umad
iw_cm 41842 1 rdma_cm
ib_core 98787 14 rdma_cm,ib_cm,ib_sa,iw_cm,xprtrdma,ib_mad,ib_srp,ib_ucm,ib_iser,ib_srpt,ib_umad,ib_uverbs,ib_ipoib,ib_isert
ib_addr 18923 3 rdma_cm,ib_core,rdma_ucm
sn_snxcpu 12946 0
vtsspp 390792 0
sep5 856884 0
socperf3 582078 1 sep5
pax 13820 0
iptable_filter 12810 1
ipmi_devintf 17572 0
ipmi_msghandler 46609 1 ipmi_devintf
ip_tables 27240 1 iptable_filter
xfs 939662 3
libcrc32c 12644 1 xfs
sd_mod 45497 6
crc_t10dif 12714 2 target_core_mod,sd_mod
crct10dif_generic 12647 0
crct10dif_pclmul 14289 1
crct10dif_common 12595 3 crct10dif_pclmul,crct10dif_generic,crc_t10dif
crc32c_intel 22079 1
ahci 29907 3
libahci 32031 1 ahci
igb 192580 0
ptp 19231 1 igb
pps_core 19106 1 ptp
i2c_algo_bit 13413 1 igb
i2c_core 40582 2 igb,i2c_algo_bit
dca 15130 1 igb
libata 218730 2 ahci,libahci
uio 19259 1 igb_uio
The messages are:
[root@SNIPER app]# ./testpmd -c 0xffffffffff -n 4 – -i --rxq=32 --txq=32 --nb-cores=32 --port-topology=paired
EAL: Detected 56 lcore(s)
EAL: Detected 2 NUMA nodes
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: No available hugepages reported in hugepages-1048576kB
EAL: Probing VFIO support…
EAL: PCI device 0000:03:00.0 on NUMA socket 0
EAL: probe driver: 8086:1533 net_e1000_igb
EAL: PCI device 0000:04:00.0 on NUMA socket 0
EAL: PCI device 0000:3b:00.0 on NUMA socket 0
EAL: probe driver: 15b3:1017 net_mlx5
net_mlx5: no Verbs device matches PCI device 0000:3b:00.0, are kernel drivers loaded?
EAL: Requested device 0000:3b:00.0 cannot be used
EAL: PCI device 0000:60:00.0 on NUMA socket 0
EAL: probe driver: 8086:37d3 net_i40e
EAL: PCI device 0000:60:00.1 on NUMA socket 0
EAL: PCI device 0000:60:00.2 on NUMA socket 0
EAL: PCI device 0000:60:00.3 on NUMA socket 0
EAL: PCI device 0000:af:00.0 on NUMA socket 1
net_mlx5: no Verbs device matches PCI device 0000:af:00.0, are kernel drivers loaded?
EAL: Requested device 0000:af:00.0 cannot be used
testpmd: No probed ethernet devices
Interactive-mode selected
testpmd: create a new mbuf pool <mbuf_pool_socket_0>: n=459456, size=2176, socket=0
testpmd: preferred mempool ops selected: ring_mp_mc
testpmd: create a new mbuf pool <mbuf_pool_socket_1>: n=459456, size=2176, socket=1
Done
