We are not using Mellanox OFED driver. Instead, we are using Linux standard driver. So, in order to capture RoCEv2 traffic, we use port mirroring in a switch to copy all traffic between host and target to a monitoring PC. This PC has a Connect4X rNIC. It was running Ubuntu 17.10 with 4.13 kernel. I was able to run Wireshark to capture the RoCEv2 traffic.
I recently upgraded that PC to Ubuntu 18.04 with 4.15 kernel. After that, I can’t capture RoCE traffic any more. I debug a bit and got these counters.
yao@Host2:~$ ethtool -S enp21s0f0 | grep rdma
rx_vport_rdma_unicast_packets: 3112973874
rx_vport_rdma_unicast_bytes: 1434773360288
tx_vport_rdma_unicast_packets: 362387261
tx_vport_rdma_unicast_bytes: 27309669154
So Mlx-5 driver drops all RDMA packets. Why is it doing that? Is there any configuration to change its behavior back to the old one (in Kernel 4.13)? I don’t see such a configuration in Mellanox_OFED_Linux_User_Manual_v4_3.pdf.
Here’s the driver info in the old kernel:
dotadmin@DavidLenovo:~$ modinfo mlx5_core
filename: /lib/modules/4.13.0-46-generic/kernel/drivers/net/ethernet/mellanox/mlx5/core/mlx5_core.ko
version: 5.0-0
license: Dual BSD/GPL
description: Mellanox Connect-IB, ConnectX-4 core driver
author: Eli Cohen <eli@mellanox.com mailto:eli@mellanox.com >
srcversion: 79D72EC6EB494E762310F77
alias: pci:v000015B3d0000A2D3svsdbcsci*
alias: pci:v000015B3d0000A2D2svsdbcsci*
alias: pci:v000015B3d0000101Csvsdbcsci*
alias: pci:v000015B3d0000101Bsvsdbcsci*
alias: pci:v000015B3d0000101Asvsdbcsci*
alias: pci:v000015B3d00001019svsdbcsci*
alias: pci:v000015B3d00001018svsdbcsci*
alias: pci:v000015B3d00001017svsdbcsci*
alias: pci:v000015B3d00001016svsdbcsci*
alias: pci:v000015B3d00001015svsdbcsci*
alias: pci:v000015B3d00001014svsdbcsci*
alias: pci:v000015B3d00001013svsdbcsci*
alias: pci:v000015B3d00001012svsdbcsci*
alias: pci:v000015B3d00001011svsdbcsci*
depends: devlink,ptp,mlxfw
intree: Y
vermagic: 4.13.0-46-generic SMP mod_unload
signat: PKCS#7
signer:
sig_key:
sig_hashalgo: md4
parm: debug_mask:debug mask: 1 = dump cmd data, 2 = dump cmd exec time, 3 = both. Default=0 (uint)
parm: prof_sel:profile selector. Valid range 0 - 2 (uint)
Here’s the driver info in the new kernel:
yao@Host2:~$ modinfo mlx5_core
filename: /lib/modules/4.15.0-36-generic/kernel/drivers/net/ethernet/mellanox/mlx5/core/mlx5_core.ko
version: 5.0-0
srcversion: C271CE9036D77E924A8E038
retpoline: Y
intree: Y
vermagic: 4.15.0-36-generic SMP mod_unload
signat: PKCS#7
signer:
sig_key:
sig_hashalgo: md4
So srcversion is different, even though version is the same.
