We ran:
./mlnxofedinstall --upstream-libs --all --without-fw-update --enable-opensm --enable-mlnx_tune
/etc/init.d/openibd restart
and after that:
systemctl start rdma
→ Failed to start rdma.service: Unit rdma.service not found.
we did:
locate rdma.service
but nothing appears. We check if rdma and rdma-core were installed and they are.
Our OS is Centos 8.2 with kernel 4.18.0-193.el8.x86_64
samerka
November 15, 2020, 2:24pm
#2
Hi ,
Which adapter are you using ?
Are you using the latest OFED 4.9-2.2.4.0 ?
Thanks,
Samer
Hi, Samer,
Yes, we are using the latest OFED 4.9-2.2.4.0-rhel8.2-x86_64
Our adapter info is the following:
root@compute-1-29 # lspci | grep Mellanox
07:00.0 Network controller: Mellanox Technologies MT27500 Family [ConnectX-3]
root@compute-1-29 # lspci -vv -s 07:00.0 | grep “Part number” -A 3
[PN] Part number: 661686-001
[EC] Engineering changes: B2
[SN] Serial number: IL213600LE
[V0] Vendor specific: HP IB FDR/EN 10/40Gb 2P 544FLR-QSFP Adptr
Thanks to you and I apologize for the slow response.
samerka
November 19, 2020, 11:05am
#4
Hi Samuel,
The adapter is HPE OEM adapter, i suggest to open a support ticket with HPE Support to get the latest working driver/firmware bundle that works with HPE ConnectX-3
Thanks,
Samer
samerka
November 19, 2020, 11:45am
#5
Hi Samuel,
Regarding the error you get : when MLNX_OFED is installed rdma service is not used, you should use openibd service only
/etc/init.d/openibd status
the command systemctl start rdma is not applicable when MLNX_OFED is installed only for inbox driver.
Thanks,
Samer
Hi, Samer, and thanks for your response.
Then, can I assume that openibd is as same as rdma service?
