I would like to flash TK1 with an eMMC image over USB from a windows machine. Currently I do it
from a Ubuntu PC, as explained here http://elinux.org/Jetson/Cloning, by :
nvflash is an ELF executable…Windows has no ability to execute this. This is essentially the flash program at its core, so you need a Linux PC to access the recovery mode Jetson.
I can’t tell if this is the same nvflash exactly. Maybe it’s another version of it, I don’t know.
So what I am trying to find out is whether there is a windows exe version of nvflash that
is capable of providing the same functionality as the elf used for Jetson boards.
This could enable me do flashing via USB from a windows PC. Such a use will simplify things in
production phase.
I doubt it is set up for a Jetson. It looks like it is designed for a video card and not a Jetson. FYI, there are many features of a PC video card which won’t work on a Jetson…a PC video card is a PCIe device, whereas a Jetson has the GPU hard wired to the memory controller without any PCI access. If for some strange reason that hacked version of nvflash worked on a Jetson’s GPU it still would not work because of the wiring to a memory controller instead of wiring to PCI.
