Is it possible to set the joint property for certain object in USD file without running physical simulation? For example, joining physical objects together and forming a fixed relationship such as Visual Components example (Model a Fixed Joint | Visual Components Academy) under the situation of without clicking the “play” key in the Omniverse Composer App.
Related topics
| Joint created in isaacsim | 0 | 79 | October 4, 2024 | |
| Are Animation Constraints or direct connections not a thing? | 18 | 383 | July 27, 2025 | |
| Physix - Disjointed body transforms with USD Composer | 1 | 61 | May 14, 2026 | |
| Creating joints at runtime | 2 | 941 | October 12, 2023 | |
| How to make rigid body joints dynamically? | 3 | 1205 | November 21, 2023 | |
| Running simulation without modifying the opened USD | 6 | 228 | January 2, 2025 | |
| [Bug Report] The joint in usd (generated from urdf converter) fail to move normally | 1 | 144 | September 18, 2025 | |
| Where to download the usd resources of "Bringing Advanced Physics to Universal Scene Description" | 3 | 714 | September 1, 2021 | |
| Adding physxTendon to revolute joints in a custom USDA for a manipulator | 1 | 676 | October 4, 2023 | |
| USDz import from fusion-360 (cant create joints between different parts of a robot body)) | 1 | 851 | December 7, 2023 |
