Is it possible to turn on the board via wol?
i am having a Jetson agx orin developer kit. and I tried wol from suspend state. it was successful.
but after shutdown(power plugged, pin9-10 short in automation header), magic packet doesn’t wake the board up
from this page. i found that “Yes, Xavier WoL only supports the suspend case. Only Orin will support the wake from full shutdown.”
can i get some details ?
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
It is not yet supported on Orin.
