Is it possible to use 12.75Mbps baud rate for uarta or uartb?
Is it possible to config the parent clock to 204M for uarta and uartb?
Currently, the maximum clock rate is 68000000 so that we can only archive the 4.25Mbps baud rate.
root@nvubuntu:/home/test# cat /sys/kernel/debug/bpmp/debug/clk/uarta/max_rate
68000000
root@nvubuntu:/home/test# cat /sys/kernel/debug/bpmp/debug/clk/uarta/possible_parents
pllp_out0 clk_32k clk_m
root@nvubuntu:/home/test# cat /sys/kernel/debug/bpmp/debug/clk/uartb/max_rate
68000000
root@nvubuntu:/home/test# cat /sys/kernel/debug/bpmp/debug/clk/uartb/possible_parents
BR
Brian
Hi brian.wu,
Are you using the devkit or custom board for Orin Nano?
It seems the pllp_out0 clock has been used by default and the max_rate is 68MHz
The maximum clock rate is configured in bpmp but it is not allowed to configure it to 204MHz.
Hi Kevin,
I use Jetpack 5.1.3 and custom board.
