Is my OpenACC code being executed in the device?
Hi! I have this code:
#pragma acc data copyin(image[0:lines*samples*bands]) \
                       copyout(count[0:FPS]) \
                       create(meanSpect[0:bands], Cov[0:bands*bands], Corr[0:bands*bands], CovEigVal[0:bands], CorrEigVal[0:bands], U[0:bands*bands], VT[0:bands*bands]) // Daba mejor rendimiento en copyin todo
    #pragma acc parallel loop vector
    for(i=0; i<bands; i++)
  		    mean=0;
          #pragma acc loop reduction(+:mean)
          for(j=0; j<N; j++)
  			    mean+=(image[(i*N)+j]);
  		    mean/=N;
          meanSpect[i]=mean;
          #pragma acc loop
          for(j=0; j<N; j++)
  			    image[(i*N)+j]=image[(i*N)+j]-mean;
    double alpha = (double)1/N, beta = 0;
    #pragma acc host_data use_device(image, Cov)
      //                                dgemm_("T", "N", &bands, &bands, &N, &alpha, image, &N, image, &N, &beta, Cov, &bands);
      cublasDgemm(handle_gemm,CUBLAS_OP_T, CUBLAS_OP_N, bands, bands, N, &alpha, image, N, image, N, &beta, Cov, bands);
	//CORRELATION
    #pragma acc parallel loop collapse(2) // Menudo collapse to wapo eh (junta los for)
    for(j=0; j<bands; j++)
        	Corr[(i*bands)+j] = Cov[(i*bands)+j]+(meanSpect[i] * meanSpect[j]);
	//SVD
    // Declaraciones movidas arriba
    #pragma acc host_data use_device(Cov, Corr, CovEigVal, CorrEigVal, U, VT)
                            //dgesvd_("N", "N", &bands, &bands, Cov, &bands, CovEigVal, U, &bands, VT, &bands, work, &lwork, &info);
      cusolverDnDgesvd(cusolverHandle,"N", "N", bands, bands, Cov, bands, CovEigVal, U, bands, VT, bands, work, lwork, rwork, info);
                            //dgesvd_("N", "N", &bands, &bands, Corr, &bands, CorrEigVal, U, &bands, VT, &bands, work, &lwork, &info);
      cusolverDnDgesvd(cusolverHandle,"N", "N", bands, bands, Corr, bands, CorrEigVal, U, bands, VT, bands, work, lwork, rwork, info);
    //ESTIMATION
    // Declaracion de count movida arriba
    double e;
    #pragma acc loop seq
    for(i=0; i<FPS; i++) count[i] = 0; // Esto probablemente no renta paralelizarlo
    #pragma acc loop seq // Estaria bien paralelizarlo pero no he encontrado forma
      // Si cada hilo tiene una variable distinta de sigmaSquareTest se puede paralelizar
    	sigmaSquareTest = (CovEigVal[i]*CovEigVal[i]+CorrEigVal[i]*CorrEigVal[i])*2/samples/lines;
    	sigmaTest = sqrt(sigmaSquareTest);
      // No merece la pena paralelizarlo ya que FPS es un define y es un numero bajo (5), ademas tampoco se deberia poder paralelizar el array count
    	for(j=1;j<=FPS;j++)
        	switch(j)
    				case 1: e = 0.906193802436823;
    				break;
    				case 2: e = 1.644976357133188;
    				break;
    				case 3: e = 2.185124219133003;
    				break;
    				case 4: e = 2.629741776210312;
    				break;
    				case 5: e = 3.015733201402701;
    				break;
            TaoTest = sqrt(2) * sigmaTest * e;
            if((CorrEigVal[i]-CovEigVal[i]) > TaoTest)
                count[j-1]++;
    #pragma acc data present(count[0:FPS])
    for(i = 0; i < FPS; i++) printf("\n%d\n",count[i]);
And I know that the three sequential loops after “// ESTIMATION” are not being executed in the GPU. Here is the thing: I want the count variable to be executed in the GPU (or device) and then copy it back to the host (with the copyout which is at the top).
Now after the whole region I have put above if I print the count array everything is set to 0s. However, if I remove the copyout or change it for a copyin and I do the same print after the parallel region, then count isn’t 0 anymore, and has its values.
This is the output of the make process, I’m using PGCC:
    404, Generating copyout(count[:5]) [if not already present]
         Generating create(VT[:bands*bands],meanSpect[:bands]) [if not already present]
         Generating copyin(image[:bands*(samples*lines)]) [if not already present]
         Generating create(CovEigVal[:bands],CorrEigVal[:bands],Corr[:bands*bands],Cov[:bands*bands],U[:bands*bands]) [if not already present]
    406, Loop is parallelizable
         Generating Tesla code
        406, #pragma acc loop vector(128) /* threadIdx.x */
        411, #pragma acc loop gang /* blockIdx.x */
             Generating reduction(+:mean)
        418, #pragma acc loop gang /* blockIdx.x */
    433, Generating Tesla code
        433, #pragma acc loop gang, vector(128) collapse(2) /* blockIdx.x threadIdx.x */
        434,   /* blockIdx.x threadIdx.x collapsed */
    454, Generated vector simd code for the loop
         Residual loop unrolled 1 times (completely unrolled)
    457, Loop not vectorized/parallelized: not countable
    488, Generating present(count[:5])
    489, Loop not vectorized/parallelized: contains call
    493, Loop not vectorized/parallelized: contains call
What count variable is being edited in the code? Why? How do I fix it?
Thank you!
The “acc loop seq” pragmas are being ignored and this code is running on the host since they aren’t part of a compute region, i.e. within a “parallel”, “kernels”, or “serial” pragma. Since you want these to run serially on the device, you can change these to:
    #pragma acc serial loop
    #pragma acc serial loop // Estaria bien paralelizarlo pero no he encontrado forma
The following code has “data” region around it, but you’re printing from the host. Is this the intent?
If you do want to print from the device, then you need to add it to a compute region. Also given “count” is already in a data region, there’s no need to have this data region. It doesn’t hurt, but just isn’t needed here.
     #pragma acc serial loop present(count[0:FPS])
or if you do want to print from the host, then you’d want to update count (after offloading the earlier loops) so the host data is synchronized:
    #pragma acc update self(count[0:FPS])
Hope this helps,
Mat
Mat you nailed it!!! Thank you SO much!
