Is `/sys/devices/platform/tegra-fuse` only available if board is fused?
Hi.
I’m using JP6.2 & Orin NX 16G module.
I can’t find /sys/devices/platform/tegra-fuse on my board, is it because of my board isn’t fused? Or am I missing any configurations?
Thank you.
hello Hnil,
this node has removed from JP-6 (i.e. kernel-5.15)
you may try running flash script (from your host) for fuse read,
$ sudo ./flash.sh --read-info -u <pkc> -v <sbk> <target_conf> <rootdev>
or,
you may try running fuse read script (from your target) for checking fuse variables.
$ sudo nv_fuse_read.sh
