HI NVteam
Our Thor T5000 product now needs to undergo high-speed signal compliance testing, covering signals such as HDMI, USB, PCI, XFI, and MIPI. I would like to ask whether Thor has a document similar to the “Jetson AGX Orin Series Modules Tuning and Compliance Guide” on Orin that I can refer to. I was unable to find any relevant documents by searching the following link: “Jetson Download Center | NVIDIA Developer”.
Hello @836577910!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
These might be relevant.
NVIDIA Jetson Thor Series Modules I/O Functional Verification Guide
https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/thor/docs/jetson_thor_tuningguide_da-12308-001.pdf
Has attachments that are discussed in the pdf.
Jetson Thor Series Modules Interface Design Guide
https://developer.nvidia.com/downloads/jetson/thor/docs/jetson-thor-series-modules-designguide-dg12084001.pdf
If the direct links above fail, then go here and scroll down to access the pdf by name:
https://developer.nvidia.com/embedded/downloads#?tx=$product,jetson_thor
Thank you very much for your reply.
I have encountered a new issue. Our Orin runs JP7.2GA. We need to perform PCIe compliance signal testing on the Orin platform. We have reviewed the “Jetson AGX Orin Series Tuning and Compliance Guide“, and found that it does not apply to JP7.2GA. Could you please advise whether there is a signal compliance test guide document available for Orin with JP7.2GA?
Thanks for sharing these references.
For Thor, NVIDIA lists regulatory and compliance documents, but could NVIDIA clarify whether a dedicated electrical signal compliance testing guide comparable to the Orin guide is available?
Regarding @836577910’s question, could NVIDIA also confirm whether the Jetson AGX Orin Series Modules Tuning and Compliance Guide v1.5 and its PCIe test procedures are compatible with JetPack 7.2 GA (Jetson Linux r39.2)?
Disclaimer: Drafted with AI assistance; technical details should be verified against NVIDIA’s official guidance.
We would appreciate your assistance in expediting this issue. Our project is pending the PCIe compliance test.
The title of this topic is about T5000 Compliance guide, but the recent posts are asking about Jetson AGX Orin PCIe compliance testing.
To keep the discussion and ensure you get the right support:
- Please close this topic
- Please create a new topic with a title that matches your actual question
Thank you,
Okay, thank you very much.
