This might be a stupid question, but I’m asking just in case. A colleague of mine is also curious about this.
I have an RTX 6000 PRO Blackwell MAX-Q Workstation on my Z790 Intel desktop. I’m wondering if it’s possible to install a ConnectX-7 card in this system and connect it to a DGX Spark to expand its compute power. I don’t think it’s possible, but I think NVIDIA officials would be the best ones to know, so I’m leaving this question here.
I asked a question because I was wondering if ConnectX-7 would normally recognize the RTX 6000 PRO Blackwell if I installed a ConnectX-7 card in the remaining PCI Express 5.0 x16 slot.
RoCE and NCCL work across x86 and arm64. Both protocols are NIC/driver config dependent, not CPU-ISA dependent. If your workload is MPI launched, then mixed arch is fine as long as each node uses its native binaries, avoid features that assume homogenious nodes.
@NVES I made the post in the other thread, but to confirm, I could take a desktop PC running Windows and WSL Ubuntu with a RTX Pro 6000 Blackwell, and then put in:
MCX753436MC-HEAB
And then connect the PC to the Spark via
MCP1650-H001E30
Those are the correct part numbers? I assume the encryption ready CX7 works fine with the Spark, even if encryption is disabled?
Edit: and is the CUDA Compute Capability of 12.0 vs 12.1 vs 12.2 of any concern?
