Isaac Manipulator ESDF data is empty, try again after few seconds
**Operating System **
Ubuntu 22.04
GPU
NVIDIA GeForce RTX 5070
Cuda
Build cuda_12.6.r12.6/compiler.34431801_0
Isaac ROS version
Isaac ROS 3.2
Hello, I am a newcomer to Isaac ROS. I have a problem related to ESDF. I hope I can get support. Here is the explanation.
I tried running the Isaac manipulator and the Isaac sim as a tutorial here
https://nvidia-isaac-ros.github.io/v/release-3.2/reference_workflows/isaac_manipulator/tutorials/tutorial_isaac_sim.html
I want to run the Pose to Pose example with Isaac sim. However, I have a problem where the robot does not want to move to the target pose. It was stuck in a certain pose.
admin@hehe-kr:/workspaces$ ros2 launch isaac_manipulator_pick_and_place isaac_sim_workflows.launch.py    workflow_type:=pose_to_pose
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2025-12-02-17-29-17-362414-hehe-kr-7027
[INFO] [launch]: Default logging verbosity is set to INFO
WARNING:root:Cannot infer URDF from `/workspaces/isaac_ros-dev/install/isaac_manipulator_pick_and_place/share/isaac_manipulator_pick_and_place`. -- using config/ur10e.urdf
WARNING:root:Cannot infer SRDF from `/workspaces/isaac_ros-dev/install/isaac_manipulator_pick_and_place/share/isaac_manipulator_pick_and_place`. -- using config/ur10e.srdf
WARNING:root:"File /workspaces/isaac_ros-dev/install/isaac_manipulator_pick_and_place/share/isaac_manipulator_pick_and_place/config/ur10e.urdf doesn't exist"
WARNING:root:The robot description will be loaded from /robot_description topic
[INFO] [launch.user]: Loading the 'sim_test_bench' workspace. Ignoring the grid_center_m / grid_size_m parameters of cumotion and esdf visualizer.
[INFO] [launch.user]: Adding nodes [ /nvblox_node ] to container manipulator_container.
[INFO] [launch.user]: Enabling nvblox for '1' 'isaac_sim' cameras configured for the 'sim_test_bench' workspace.
[INFO] [component_container_mt-1]: process started with pid [7070]
[INFO] [robot_state_publisher-2]: process started with pid [7072]
[INFO] [joint_state_publisher-3]: process started with pid [7074]
[INFO] [cumotion_goal_set_planner_node-4]: process started with pid [7076]
[INFO] [robot_segmenter_node-5]: process started with pid [7078]
[INFO] [attach_object_server_node-6]: process started with pid [7080]
[INFO] [move_group-7]: process started with pid [7082]
[INFO] [rviz2-8]: process started with pid [7084]
[INFO] [joint_parser_node.py-9]: process started with pid [7086]
[INFO] [ros2_control_node-10]: process started with pid [7088]
[INFO] [spawner-11]: process started with pid [7090]
[INFO] [isaac_sim_gripper_action_server.py-12]: process started with pid [7093]
[INFO] [spawner-13]: process started with pid [7096]
[INFO] [pose_to_pose_node-14]: process started with pid [7105]
[robot_state_publisher-2] [INFO] [1764664157.704587951] [robot_state_publisher]: got segment base
[robot_state_publisher-2] [INFO] [1764664157.704630666] [robot_state_publisher]: got segment base_link
[robot_state_publisher-2] [INFO] [1764664157.704635692] [robot_state_publisher]: got segment base_link_inertia
[robot_state_publisher-2] [INFO] [1764664157.704638911] [robot_state_publisher]: got segment flange
[robot_state_publisher-2] [INFO] [1764664157.704642183] [robot_state_publisher]: got segment forearm_link
[robot_state_publisher-2] [INFO] [1764664157.704645182] [robot_state_publisher]: got segment ft_frame
[robot_state_publisher-2] [INFO] [1764664157.704648442] [robot_state_publisher]: got segment grasp_frame
[robot_state_publisher-2] [INFO] [1764664157.704651404] [robot_state_publisher]: got segment gripper_frame
[robot_state_publisher-2] [INFO] [1764664157.704654631] [robot_state_publisher]: got segment left_inner_finger
[robot_state_publisher-2] [INFO] [1764664157.704657757] [robot_state_publisher]: got segment left_inner_finger_pad
[robot_state_publisher-2] [INFO] [1764664157.704661053] [robot_state_publisher]: got segment left_inner_knuckle
[robot_state_publisher-2] [INFO] [1764664157.704664100] [robot_state_publisher]: got segment left_outer_finger
[robot_state_publisher-2] [INFO] [1764664157.704667046] [robot_state_publisher]: got segment left_outer_knuckle
[robot_state_publisher-2] [INFO] [1764664157.704670065] [robot_state_publisher]: got segment right_inner_finger
[robot_state_publisher-2] [INFO] [1764664157.704673986] [robot_state_publisher]: got segment right_inner_finger_pad
[robot_state_publisher-2] [INFO] [1764664157.704677065] [robot_state_publisher]: got segment right_inner_knuckle
[robot_state_publisher-2] [INFO] [1764664157.704679986] [robot_state_publisher]: got segment right_outer_finger
[robot_state_publisher-2] [INFO] [1764664157.704682836] [robot_state_publisher]: got segment right_outer_knuckle
[robot_state_publisher-2] [INFO] [1764664157.704685666] [robot_state_publisher]: got segment robotiq_140_base_link
[robot_state_publisher-2] [INFO] [1764664157.704688697] [robot_state_publisher]: got segment robotiq_base_link
[robot_state_publisher-2] [INFO] [1764664157.704691548] [robot_state_publisher]: got segment shoulder_link
[robot_state_publisher-2] [INFO] [1764664157.704694580] [robot_state_publisher]: got segment tool0
[robot_state_publisher-2] [INFO] [1764664157.704697575] [robot_state_publisher]: got segment upper_arm_link
[robot_state_publisher-2] [INFO] [1764664157.704700493] [robot_state_publisher]: got segment world
[robot_state_publisher-2] [INFO] [1764664157.704703484] [robot_state_publisher]: got segment wrist_1_link
[robot_state_publisher-2] [INFO] [1764664157.704706466] [robot_state_publisher]: got segment wrist_2_link
[robot_state_publisher-2] [INFO] [1764664157.704709214] [robot_state_publisher]: got segment wrist_3_link
[ros2_control_node-10] [INFO] [1764664157.717214146] [controller_manager]: Subscribing to '~/robot_description' topic for robot description file.
[ros2_control_node-10] [INFO] [1764664157.717597452] [controller_manager]: update rate is 100 Hz
[ros2_control_node-10] [INFO] [1764664157.717613917] [controller_manager]: Spawning controller_manager RT thread with scheduler priority: 50
[ros2_control_node-10] [WARN] [1764664157.717691430] [controller_manager]: No real-time kernel detected on this system. See [https://control.ros.org/master/doc/ros2_control/controller_manager/doc/userdoc.html] for details on how to enable realtime scheduling.
[move_group-7] [INFO] [1764664157.718273136] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0 seconds
[move_group-7] [INFO] [1764664157.718317715] [moveit_robot_model.robot_model]: Loading robot model 'robotiq_gripper'...
[move_group-7] [INFO] [1764664157.718325221] [moveit_robot_model.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ros2_control_node-10] [INFO] [1764664157.731587805] [controller_manager]: Received robot description file.
[ros2_control_node-10] [INFO] [1764664157.731872391] [resource_manager]: Loading hardware 'ur_ros2_control_sim'
[ros2_control_node-10] [INFO] [1764664157.732610447] [resource_manager]: Initialize hardware 'ur_ros2_control_sim'
[ros2_control_node-10] [INFO] [1764664157.735813678] [resource_manager]: Successful initialization of hardware 'ur_ros2_control_sim'
[ros2_control_node-10] [INFO] [1764664157.735883284] [resource_manager]: 'configure' hardware 'ur_ros2_control_sim'
[ros2_control_node-10] [INFO] [1764664157.735892161] [resource_manager]: Successful 'configure' of hardware 'ur_ros2_control_sim'
[ros2_control_node-10] [INFO] [1764664157.735900298] [resource_manager]: 'activate' hardware 'ur_ros2_control_sim'
[ros2_control_node-10] [INFO] [1764664157.735905065] [resource_manager]: Successful 'activate' of hardware 'ur_ros2_control_sim'
[move_group-7] [INFO] [1764664157.797378784] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Publishing maintained planning scene on 'monitored_planning_scene'
[move_group-7] [INFO] [1764664157.797925252] [moveit.ros_planning_interface.moveit_cpp]: Listening to 'joint_states' for joint states
[move_group-7] [INFO] [1764664157.798722699] [moveit_ros.current_state_monitor]: Listening to joint states on topic 'joint_states'
[move_group-7] [INFO] [1764664157.799543569] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/attached_collision_object' for attached collision objects
[move_group-7] [INFO] [1764664157.799770390] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[move_group-7] [INFO] [1764664157.801090802] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/planning_scene'
[move_group-7] [INFO] [1764664157.801311384] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting world geometry update monitor for collision objects, attached objects, octomap updates.
[move_group-7] [INFO] [1764664157.801984884] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to 'collision_object'
[move_group-7] [INFO] [1764664157.802688949] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to 'planning_scene_world' for planning scene world geometry
[move_group-7] [WARN] [1764664157.803242147] [moveit.ros.occupancy_map_monitor.middleware_handle]: Resolution not specified for Octomap. Assuming resolution = 0.1 instead
[move_group-7] [ERROR] [1764664157.803787088] [moveit.ros.occupancy_map_monitor.middleware_handle]: No 3D sensor plugin(s) defined for octomap updates
[move_group-7] [INFO] [1764664157.808225137] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'isaac_ros_cumotion'
[move_group-7] [WARN] [1764664157.814413944] [pluginlib.ClassLoader]: given plugin name 'libisaac_ros_cumotion_moveit' should be 'isaac_ros_cumotion_moveit' for better portability
[rviz2-8] QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-admin'
[move_group-7] [INFO] [1764664157.826588646] [moveit.ros_planning.planning_pipeline]: Using planning interface 'Generate minimum-jerk trajectories using NVIDIA Isaac ROS cuMotion'
[move_group-7] [INFO] [1764664157.827852356] [moveit_ros.fix_workspace_bounds]: Param 'isaac_ros_cumotion.default_workspace_bounds' was not set. Using default value: 10.000000
[move_group-7] [INFO] [1764664157.828029131] [moveit_ros.fix_start_state_bounds]: Param 'isaac_ros_cumotion.start_state_max_bounds_error' was set to 0.100000
[move_group-7] [INFO] [1764664157.828137433] [moveit_ros.fix_start_state_bounds]: Param 'isaac_ros_cumotion.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-7] [INFO] [1764664157.828234292] [moveit_ros.fix_start_state_collision]: Param 'isaac_ros_cumotion.start_state_max_dt' was not set. Using default value: 0.500000
[move_group-7] [INFO] [1764664157.828322684] [moveit_ros.fix_start_state_collision]: Param 'isaac_ros_cumotion.jiggle_fraction' was not set. Using default value: 0.020000
[move_group-7] [INFO] [1764664157.828412235] [moveit_ros.fix_start_state_collision]: Param 'isaac_ros_cumotion.max_sampling_attempts' was not set. Using default value: 100
[move_group-7] [INFO] [1764664157.828500251] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Workspace Bounds'
[move_group-7] [INFO] [1764664157.828585111] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Bounds'
[move_group-7] [INFO] [1764664157.828667420] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State In Collision'
[move_group-7] [INFO] [1764664157.828752182] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Path Constraints'
[move_group-7] [INFO] [1764664157.829384075] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'ompl'
[move_group-7] [INFO] [1764664157.830112946] [moveit.ros_planning.planning_pipeline]: Multiple planning plugins available. You should specify the '~planning_plugin' parameter. Using 'chomp_interface/CHOMPPlanner' for now.
[move_group-7] [INFO] [1764664157.831152631] [moveit.ros_planning.planning_pipeline]: Using planning interface 'CHOMP'
[move_group-7] [WARN] [1764664157.831819082] [moveit.ros_planning_interface.moveit_cpp]: Skipping duplicate entry for planning pipeline 'ompl'.
[move_group-7] [INFO] [1764664157.839637414] [moveit.plugins.moveit_simple_controller_manager]: Added FollowJointTrajectory controller for scaled_joint_trajectory_controller
[move_group-7] [INFO] [1764664157.840608946] [moveit.plugins.moveit_simple_controller_manager]: Added FollowJointTrajectory controller for joint_trajectory_controller
[move_group-7] [INFO] [1764664157.840929563] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
[move_group-7] [INFO] [1764664157.841096789] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
[move_group-7] [INFO] [1764664157.841348898] [moveit_ros.trajectory_execution_manager]: Trajectory execution is managing controllers
[move_group-7] [INFO] [1764664157.841534752] [move_group.move_group]: MoveGroup debug mode is ON
[move_group-7] [INFO] [1764664157.855782644] [move_group.move_group]:
[move_group-7]
[move_group-7] ********************************************************
[move_group-7] * MoveGroup using:
[move_group-7] *     - ApplyPlanningSceneService
[move_group-7] *     - ClearOctomapService
[move_group-7] *     - ExecuteTaskSolution
[move_group-7] *     - CartesianPathService
[move_group-7] *     - ExecuteTrajectoryAction
[move_group-7] *     - GetPlanningSceneService
[move_group-7] *     - KinematicsService
[move_group-7] *     - MoveAction
[move_group-7] *     - MotionPlanService
[move_group-7] *     - QueryPlannersService
[move_group-7] *     - StateValidationService
[move_group-7]
[move_group-7] [INFO] [1764664157.855820060] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context using planning plugin isaac_ros_cumotion_moveit/CumotionPlanner
[move_group-7] [INFO] [1764664157.855829908] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context initialization complete
[move_group-7] Loading 'move_group/ApplyPlanningSceneService'...
[move_group-7] Loading 'move_group/ClearOctomapService'...
[move_group-7] Loading 'move_group/ExecuteTaskSolutionCapability'...
[move_group-7] Loading 'move_group/MoveGroupCartesianPathService'...
[move_group-7] Loading 'move_group/MoveGroupExecuteTrajectoryAction'...
[move_group-7] Loading 'move_group/MoveGroupGetPlanningSceneService'...
[move_group-7] Loading 'move_group/MoveGroupKinematicsService'...
[move_group-7] Loading 'move_group/MoveGroupMoveAction'...
[move_group-7] Loading 'move_group/MoveGroupPlanService'...
[move_group-7] Loading 'move_group/MoveGroupQueryPlannersService'...
[move_group-7] Loading 'move_group/MoveGroupStateValidationService'...
[move_group-7]
[move_group-7] You can start planning now!
[move_group-7]
[joint_state_publisher-3] [INFO] [1764664158.015557185] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...
[ros2_control_node-10] [INFO] [1764664158.165654656] [controller_manager]: Loading controller 'scaled_joint_trajectory_controller'
[component_container_mt-1] WARNING: Logging before InitGoogleLogging() is written to STDERR
[component_container_mt-1] I1202 17:29:18.166082  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[ros2_control_node-10] [WARN] [1764664158.170875193] [scaled_joint_trajectory_controller]: [Deprecated]: "allow_nonzero_velocity_at_trajectory_end" is set to true. The default behavior will change to false.
[ros2_control_node-10] [INFO] [1764664158.204959616] [controller_manager]: Loading controller 'joint_state_broadcaster'
[spawner-11] [INFO] [1764664158.218293537] [spawner_scaled_joint_trajectory_controller]: Loaded scaled_joint_trajectory_controller
[ros2_control_node-10] [INFO] [1764664158.265060963] [controller_manager]: Configuring controller 'scaled_joint_trajectory_controller'
[ros2_control_node-10] [INFO] [1764664158.265257405] [scaled_joint_trajectory_controller]: No specific joint names are used for command interfaces. Using 'joints' parameter.
[ros2_control_node-10] [INFO] [1764664158.265279815] [scaled_joint_trajectory_controller]: Command interfaces are [position] and state interfaces are [position velocity].
[ros2_control_node-10] [INFO] [1764664158.265300296] [scaled_joint_trajectory_controller]: Using 'splines' interpolation method.
[ros2_control_node-10] [INFO] [1764664158.265766846] [scaled_joint_trajectory_controller]: Controller state will be published at 50.00 Hz.
[move_group-7] [INFO] [1764664158.266901570] [moveit_move_group_default_capabilities.move_action_capability]: Received request
[move_group-7] [INFO] [1764664158.267053542] [moveit_move_group_default_capabilities.move_action_capability]: executing..
[ros2_control_node-10] [INFO] [1764664158.267594359] [scaled_joint_trajectory_controller]: Action status changes will be monitored at 20.00 Hz.
[spawner-13] [INFO] [1764664158.273153519] [spawner_joint_state_broadcaster]: Loaded joint_state_broadcaster
[pose_to_pose_node-14] [INFO] [1764664158.281463521] [pose_to_pose_node]: Planning Goal request accepted!
[ros2_control_node-10] [INFO] [1764664158.300651698] [controller_manager]: Configuring controller 'joint_state_broadcaster'
[ros2_control_node-10] [INFO] [1764664158.300725791] [joint_state_broadcaster]: 'joints' or 'interfaces' parameter is empty. All available state interfaces will be published
[spawner-11] [INFO] [1764664158.410319426] [spawner_scaled_joint_trajectory_controller]: Configured and activated scaled_joint_trajectory_controller
[move_group-7] [INFO] [1764664158.488928265] [moveit_move_group_default_capabilities.move_action_capability]: Combined planning and execution request received for MoveGroup action. Forwarding to planning and execution pipeline.
[move_group-7] [WARN] [1764664158.488952614] [moveit_move_group_capabilities_base.move_group_capability]: Execution of motions should always start at the robot's current state. Ignoring the state supplied as start state in the motion planning request
[move_group-7] [WARN] [1764664158.488956097] [moveit_move_group_capabilities_base.move_group_capability]: Execution of motions should always start at the robot's current state. Ignoring the state supplied as difference in the planning scene diff
[move_group-7] [INFO] [1764664158.488961560] [moveit_ros.plan_execution]: Planning attempt 1 of at most 1
[move_group-7] [INFO] [1764664158.488967501] [moveit_move_group_capabilities_base.move_group_capability]: Using planning pipeline 'isaac_ros_cumotion'
[move_group-7] [INFO] [1764664158.489257888] [move_group]: Planning trajectory
[spawner-13] [INFO] [1764664158.583841212] [spawner_joint_state_broadcaster]: Configured and activated joint_state_broadcaster
[INFO] [spawner-11]: process has finished cleanly [pid 7090]
[INFO] [spawner-13]: process has finished cleanly [pid 7096]
[rviz2-8] [INFO] [1764664159.696420178] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-8] [INFO] [1764664159.696521001] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
[rviz2-8] [INFO] [1764664159.927296464] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-8] [INFO] [1764664159.973586880] [rviz2]: Connected on namespace: /end_effector_marker
[cumotion_goal_set_planner_node-4] [INFO] [1764664159.998420413] [cumotion_planner]: Loading grid center and dims from workspace file: /workspaces/isaac_ros-dev/install/isaac_manipulator_bringup/share/isaac_manipulator_bringup/config/nvblox/workspace_bounds/sim_test_bench.yaml.
[cumotion_goal_set_planner_node-4] [INFO] [1764664160.000334910] [cumotion_planner]: Loaded grid dims: [2.0, 2.0, 1.0], voxel size: 0.01
[robot_segmenter_node-5] [INFO] [1764664160.960979183] [robot_segmenter]: Node initialized with 1 cameras
[robot_segmenter_node-5] [INFO] [1764664160.961137146] [robot_segmenter]: Starting CumotionRobotSegmenter node
[rviz2-8] [INFO] [1764664160.984450207] [rviz2]: Stereo is NOT SUPPORTED
[cumotion_goal_set_planner_node-4] [INFO] [1764664161.004009907] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664162.005049785] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[component_container_mt-1] I1202 17:29:22.386195  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[attach_object_server_node-6] [INFO] [1764664162.426441961] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664163.006274172] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664163.427687444] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664164.007694869] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664164.429130705] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664165.008817269] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664165.430923931] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664166.010246109] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[component_container_mt-1] I1202 17:29:26.274500  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9TsdfVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:26.288043  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:26.319164  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[attach_object_server_node-6] [INFO] [1764664166.432604984] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664167.012047731] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664167.433966239] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664168.013855037] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664168.435440061] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664169.015303376] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664169.436803215] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664170.016727833] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[component_container_mt-1] I1202 17:29:30.160343  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_10ColorVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:30.165772  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:30.197280  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[attach_object_server_node-6] [INFO] [1764664170.438255978] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664171.017925118] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664171.439714886] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664172.019405496] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664172.441181460] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664173.021295013] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[attach_object_server_node-6] [INFO] [1764664173.442501372] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[cumotion_goal_set_planner_node-4] [INFO] [1764664174.023213465] [cumotion_planner]: Service(/nvblox_node/get_esdf_and_gradient) not available, waiting again...
[component_container_mt-1] I1202 17:29:34.045253  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14FreespaceVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.050858  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.068918  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.070269  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14OccupancyVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.074852  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.348237  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.349406  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9EsdfVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.349467  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.364722  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.367161  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox10BlockLayerINS_9MeshBlockEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.367167  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9TsdfVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.367169  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_10ColorVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.367170  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14FreespaceVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.367172  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14OccupancyVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.367172  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9EsdfVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.367178  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_10BlockLayerINS_9MeshBlockEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.374281  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.398592  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.399796  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9TsdfVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.404317  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.423763  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.424932  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_10ColorVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.429414  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[attach_object_server_node-6] [INFO] [1764664174.443967998] [object_attachment]: Service(nvblox_node/get_esdf_and_gradient) not available, waiting again...
[component_container_mt-1] I1202 17:29:34.446798  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.448477  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14FreespaceVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.450856  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.476073  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.478379  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_14OccupancyVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.483987  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.499424  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.500598  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox15VoxelBlockLayerINS_9EsdfVoxelEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.500648  7135 block_memory_pool_impl.h:65] Expanding the memory pool with 2048 blocks. Number of allocated blocks: 2048
[component_container_mt-1] I1202 17:29:34.517537  7135 gpu_hash_interface_impl.cuh:83] Creating a GPUHashImpl with requested capacity of 4096 blocks. Real capacity: 4096
[component_container_mt-1] I1202 17:29:34.518699  7135 layer_cake_impl.h:32] Adding Layer with type: N6nvblox10BlockLayerINS_9MeshBlockEEE, voxel_size: 0.01, and memory_type: kDevice to LayerCake.
[component_container_mt-1] I1202 17:29:34.518702  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9TsdfVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.518704  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_10ColorVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.518705  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14FreespaceVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.518707  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_14OccupancyVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.518707  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_15VoxelBlockLayerINS_9EsdfVoxelEEEEE to LayerCake.
[component_container_mt-1] I1202 17:29:34.518708  7135 layer_cake_streamer_impl.h:79] Adding Streamer with type: N6nvblox25LayerStreamerOldestBlocksINS_10BlockLayerINS_9MeshBlockEEEEE to LayerCake.
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/nvblox_node' in container 'manipulator_container'
[attach_object_server_node-6] [INFO] [1764664174.694632394] [object_attachment]: Node initialized with 1 cameras
[cumotion_goal_set_planner_node-4] [INFO] [1764664179.429419917] [cumotion_planner]: warming up cuMotion, wait until ready
[cumotion_goal_set_planner_node-4] [INFO] [1764664195.870845291] [cumotion_planner]: cuMotion is ready for planning queries!
[move_group-7] [INFO] [1764664195.883775188] [move_group]: Sending goal
[move_group-7] [INFO] [1764664195.886052132] [move_group]: Goal accepted by server, waiting for result
[cumotion_goal_set_planner_node-4] [INFO] [1764664195.886945556] [cumotion_planner]: Executing goal...
[cumotion_goal_set_planner_node-4] [INFO] [1764664195.887115137] [cumotion_planner]: Planning with time_dilation_factor: 1.0
[cumotion_goal_set_planner_node-4] [INFO] [1764664195.887323767] [cumotion_planner]: Calling ESDF service
[cumotion_goal_set_planner_node-4] [INFO] [1764664195.887483566] [cumotion_planner]: ESDF  req = geometry_msgs.msg.Point(x=-1.5, y=-1.0, z=-0.2), geometry_msgs.msg.Vector3(x=2.0, y=2.0, z=1.0)
[cumotion_goal_set_planner_node-4] [ERROR] [1764664207.554866260] [cumotion_planner]: ESDF data is empty, try again after few seconds.
[cumotion_goal_set_planner_node-4] [ERROR] [1764664207.555606868] [cumotion_planner]: World update failed.
[move_group-7] [INFO] [1764664207.556317229] [move_group]: Received result
[move_group-7] [INFO] [1764664207.556547941] [move_group]: Received trajectory result
[move_group-7] [ERROR] [1764664207.556586036] [move_group]: No trajectory
[move_group-7] [INFO] [1764664207.556755451] [moveit_move_group_default_capabilities.move_action_capability]: No motion plan found. No execution attempted.
[pose_to_pose_node-14] [ERROR] [1764664207.559549054] [pose_to_pose_node]: Planning failed!
[pose_to_pose_node-14] [WARN] [1764664207.562307023] [pose_to_pose_node]: target pose was not reachable by planner, trying again                                       on the next iteration
[move_group-7] [INFO] [1764664207.563656393] [moveit_move_group_default_capabilities.move_action_capability]: Received request
[move_group-7] [INFO] [1764664207.563726838] [moveit_move_group_default_capabilities.move_action_capability]: executing..
[move_group-7] [INFO] [1764664207.563786222] [moveit_move_group_default_capabilities.move_action_capability]: Combined planning and execution request received for MoveGroup action. Forwarding to planning and execution pipeline.
[move_group-7] [WARN] [1764664207.563798104] [moveit_move_group_capabilities_base.move_group_capability]: Execution of motions should always start at the robot's current state. Ignoring the state supplied as start state in the motion planning request
[move_group-7] [WARN] [1764664207.563842261] [moveit_move_group_capabilities_base.move_group_capability]: Execution of motions should always start at the robot's current state. Ignoring the state supplied as difference in the planning scene diff
[move_group-7] [INFO] [1764664207.563845956] [moveit_ros.plan_execution]: Planning attempt 1 of at most 1
[move_group-7] [INFO] [1764664207.563848915] [moveit_move_group_capabilities_base.move_group_capability]: Using planning pipeline 'isaac_ros_cumotion'
[move_group-7] [INFO] [1764664207.564153731] [move_group]: Planning trajectory
[move_group-7] [INFO] [1764664207.564301190] [move_group]: Sending goal
[pose_to_pose_node-14] [INFO] [1764664207.564789756] [pose_to_pose_node]: Planning Goal request accepted!
[move_group-7] [INFO] [1764664207.566732045] [move_group]: Goal accepted by server, waiting for result
[cumotion_goal_set_planner_node-4] [INFO] [1764664207.567828667] [cumotion_planner]: Executing goal...
[cumotion_goal_set_planner_node-4] [INFO] [1764664207.568171930] [cumotion_planner]: Planning with time_dilation_factor: 1.0
[cumotion_goal_set_planner_node-4] [INFO] [1764664207.568548323] [cumotion_planner]: Calling ESDF service
[cumotion_goal_set_planner_node-4] [INFO] [1764664207.568881181] [cumotion_planner]: ESDF  req = geometry_msgs.msg.Point(x=-1.5, y=-1.0, z=-0.2), geometry_msgs.msg.Vector3(x=2.0, y=2.0, z=1.0)
[cumotion_goal_set_planner_node-4] [ERROR] [1764664220.633900683] [cumotion_planner]: ESDF data is empty, try again after few seconds.
[cumotion_goal_set_planner_node-4] [ERROR] [1764664220.635145671] [cumotion_planner]: World update failed.
[move_group-7] [INFO] [1764664220.636090279] [move_group]: Received result
[move_group-7] [INFO] [1764664220.636099001] [move_group]: Checking results
[move_group-7] [INFO] [1764664220.636185166] [move_group]: Success
[move_group-7] [INFO] [1764664220.641255734] [move_group]: Received trajectory result
[move_group-7] [ERROR] [1764664220.641270926] [move_group]: No trajectory
[move_group-7] [INFO] [1764664220.641297962] [moveit_move_group_default_capabilities.move_action_capability]: No motion plan found. No execution attempted.
[pose_to_pose_node-14] [ERROR] [1764664220.642659024] [pose_to_pose_node]: Planning failed!
[pose_to_pose_node-14] [WARN] [1764664220.651643142] [pose_to_pose_node]: target pose was not reachable by planner, trying again                                       on the next iteration
[move_group-7] [INFO] [1764664220.654130155] [moveit_move_group_default_capabilities.move_action_capability]: Received request
[move_group-7] [INFO] [1764664220.654247237] [moveit_move_group_default_capabilities.move_action_capability]: executing..
[move_group-7] [INFO] [1764664220.654325253] [moveit_move_group_default_capabilities.move_action_capability]: Combined planning and execution request received for MoveGroup action. Forwarding to planning and execution pipeline.
[move_group-7] [WARN] [1764664220.654339385] [moveit_move_group_capabilities_base.move_group_capability]: Execution of motions should always start at the robot's current state. Ignoring the state supplied as start state in the motion planning request
[move_group-7] [WARN] [1764664220.654345015] [moveit_move_group_capabilities_base.move_group_capability]: Execution of motions should always start at the robot's current state. Ignoring the state supplied as difference in the planning scene diff
[move_group-7] [INFO] [1764664220.654349593] [moveit_ros.plan_execution]: Planning attempt 1 of at most 1
[move_group-7] [INFO] [1764664220.654354237] [moveit_move_group_capabilities_base.move_group_capability]: Using planning pipeline 'isaac_ros_cumotion'
[move_group-7] [INFO] [1764664220.654743112] [move_group]: Planning trajectory
[move_group-7] [INFO] [1764664220.654974974] [move_group]: Sending goal
[pose_to_pose_node-14] [INFO] [1764664220.656066423] [pose_to_pose_node]: Planning Goal request accepted!
[move_group-7] [INFO] [1764664220.660791575] [move_group]: Goal accepted by server, waiting for result
[cumotion_goal_set_planner_node-4] [INFO] [1764664220.665466314] [cumotion_planner]: Executing goal...
[cumotion_goal_set_planner_node-4] [INFO] [1764664220.666092859] [cumotion_planner]: Planning with time_dilation_factor: 1.0
[cumotion_goal_set_planner_node-4] [INFO] [1764664220.666782254] [cumotion_planner]: Calling ESDF service
[cumotion_goal_set_planner_node-4] [INFO] [1764664220.667271680] [cumotion_planner]: ESDF  req = geometry_msgs.msg.Point(x=-1.5, y=-1.0, z=-0.2), geometry_msgs.msg.Vector3(x=2.0, y=2.0, z=1.0)
From the error, it shows that
I am only following instructions on the website. Is there any opinion on the root cause of this problem and how to fix it? Thank you
Hello @salazar88,
Welcome to the Isaac ROS forum, and thanks for your post!
Based on the log you provided, the planner is failing because the ESDF that cuMotion requests from NVBlox is empty, meaning there’s no collision world to plan through.
You may want to double-check that NVBlox is running correctly.
Here are a few points you could check:
  • NVBlox requires both depth and a pose for the camera, depth alone is not sufficient. Please verify that the relevant topics are being published correctly.
  • A valid transform chain from the camera frame to the world/base must exist on TF for integration.
  • In RViz, you can add /nvblox_node/mesh (or /nvblox_node/static_map_slice) for visualization. If nothing appears after a few seconds while depth data is flowing, mapping is not occurring (likely due to issues with inputs, TF, or configuration).
  • Use ros2 param get /nvblox_node compute_esdf to ensure it is set to true.
Good luck with the rest of your implementation!
