NVIDIA Developer Forums
Isaac_ros_centerpose inference with Intel RealSense D435 stuck at "Unable to get power limit for GPU 0"
Robotics & Edge Computing
Robotics - Isaac
Isaac ROS
mona.jalal
February 7, 2025, 7:19pm
4
I redid all steps and it works.
1726×972 74.9 KB
Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8)
show post in topic
Related topics
Topic
Replies
Views
Activity
/Centerpose/image-visualized no inference image display
Isaac ROS
1
27
February 11, 2025
Isaac_ros_centerpose on a trained model for custom object usin TAO toolkit and data from isaac sim yields no inference
Isaac ROS
camera
ros
docker
isaac-ros-pose-estimation
ros-2-humble
7
41
February 12, 2025
No inference results for custom object using isaac_ros_centerpose - Compression requires single-channel 32bit-floating point or 16bit raw depth images
Isaac ROS
2
30
February 12, 2025
Isaac_ros_foundationpose tracking takes approximately 20 seconds to show pose detection results upon starting rviz
Isaac ROS
camera
mesh
isaac-ros-object-detection
10
106
March 24, 2025
Running Isaac ROS Packages with Intel RealSense D457
Isaac ROS
2
168
August 29, 2024
Isacc_ros_centerpose
Isaac ROS
9
78
January 10, 2025
Isaac_ros_ess Visualization Problem
Isaac ROS
camera
10
188
November 1, 2024
An Three error occurred during Foundationpose Quickstart
Isaac ROS
18
433
September 1, 2024
Isaac_ros_visual_slam Quickstart - No PCL - ubuntu 22 x86, RS 435i
Isaac ROS
1
169
June 24, 2024
Jetson Orin Nano with Intel Realsense D455--isaac_ros_visual_slam problem
Isaac ROS
jetson
isaac-ros-vslam
3
124
November 8, 2024
