Does Isaac ROS VSLAM start to publish poses after you move the camera after this “tracker lost”? The “tracker lost” condition is not necessarily a failure here. You’ll also want to make sure to disable the Realsense IR emitter which can cause issues for VSLAM as a pattern that moves with you in the scene.
You can echo the camera_info topic and make sure at least the intrinsics/distortion parameters are present.
I turned off the emitters (no red light from the diodes), however, the result is still the same. And it lag severely. My GPU is GTX1060M, CPU Intel i7 (7th Gen).
ros2 topic echo /camera/infra1/camera_info returned the following:
Also, when it turned on, there’s a message says “[component_container-1] [INFO] [1673514474.465927978] [visual_slam_node]: Enable IMU integrator: false”. Does that mean IMU is off?
