Isaac Sim 4.5 is now available.
The 4.5 release offers a number of significant changes, including the following:
- Renaming Extensions in Isaac Sim: With the release of Isaac Sim 4.5, extensions have been renamed and divided to enhance modularity, facilitating end-users in building custom applications using these extensions, including Isaac Lab. Users should ensure their code is updated to reflect the new extension names. Learn more.
- A reference application template: Isaac Sim has been redesigned as a customizable reference application. A minimal template for faster startup and a full template with complete functionality along with all dependencies. Additionally, users can take advantage of templates designed specifically for Synthetic Data Generation (SDG) and Software-in-Loop (SIL).
- Improved URDF import and setup: User Interface has been simplified to provide a more streamlined process and align with how other formats are imported, making simulations more stable.
- Improved physics simulation and modeling: Define and configure various joint types between robot components, setting parameters like stiffness and damping to fine-tune joint behavior.
- New joint visualization tool: Enables you to inspect the physics properties of selected prims, including their position, rotation, linear and angular velocities, and accelerations.
NOTE: With significant changes to renaming and restructuring, users should ensure that the existing code uses the new extension names.
Download the release now and learn more about the newest features in our blog.
