Problem
I downloaded the Omniverse Launcher on Ubuntu 22.04 and installed the Isaac Sim Compatibility Checker using its UI. However, when I clicked to start it, there was no response (the operation failed).
It seems that Compatibility Checker is just a simple test tool. But I even cant’t run it successfully.
When I run the script manually,the error message is as follows:
I also check the Isaac Sim Compatibility Checker log,and i also find some error message:
2024-12-13 02:57:08 [290ms] [Info] [omni.platforminfo.plugin] realpath(libX11.so.6.3.0) failed (errno = 2)
Isaac Sim Compatibility Checker version
4.2.0
Operating System
Ubuntu 22.04
GPU Information
Driver Version: 550.54.14
