Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
Topic Description
Detailed Description
Isaac Sim 4.5 doesn’t seem to be aligned with the Omniverse Kit documentation regarding the Python environment. Embedded Python — Omniverse Kit
Out of the box, instead of using the included python executable (which is also indicated in the /plugins/carb.scripting-python.plugin/pythonHome setting of kit-core.json), it uses whichever executable is the default in the shell that launches it. It can thus be manipulated through the $PATH variable or similar, which shouldn’t be the behavior according to the documentation.
Steps to Reproduce
- Launch Isaac Sim with
isaacsim/isaac-sim.sh - Open Script Editor
- Run the following command:
import sys; print(sys.executable) - The script prints out
/usr/bin/python3instead of the kit-included executable.
I can make the behavior change by modifying the PATH variable:
export PATH="${HOME}/isaacsim/kit/python":$PATH- <repeat steps 1-3 above>
- The printout changes to
/home/<username>/isaacsim/kit/python/python3which is the expected one.
Screenshots or Videos
Is this expected behavior with Isaac Sim 4.5?
