I am using isaacsim 4.2 on Windows 11. I recently encountered the following error 1 when installing ros2 bridge. However, I cannot install the new version of isaacsim.ros2.bridge because the following error 2 appears. For some reason, I did not update to 4.5. Is there any solution?
error1:Error
Failed to solve all extension dependencies:Failed to resolve extension dependencies. Failure hints:lomni.isaac,ros2 bridge-3.0.2]dependency: isaacsim.ros2.bridge. ( version."~ } can’t be satisfied. Available versions:(none found)
Platform incompatible packages:isaacsim.ros2 bridge-4.1.15+106.5.3.1x64-[isaacsim.ros2.bridge-4,1.15+106.5.0.wx64] (registry)isaacsim.ros2.bridge-4,1,15+106.5.0.1x64isaacsim.ros2.bridge-4.1.15+106.5.3.wx64Synced registries:
kit/default: found 3540 packageskit/sdkfound 611 packages-kit/community: found 410 packages
error2:Error
Can’t install: no compatible packages of extension isaacsim.ros2bridge found.
Please use “omni.isaac.ros2_bridge” in Isaac Sim 4.2.0.
