Isaacsim 6.0.1 tutorial 7 --- Adding physics fails
Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
6.0.1
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX A4500
  • Driver Version: 580.159.03
Topic Description
Adding Physics material to robot manipulator finger fails saying " failed to bind to material as they are instance proxies “path to/collisions/mesh_1/box”
Detailed Description
I am trying to replicate tutorial 7 to simulate a pick and place robot manipulator, and while adding physics material to the gripper fingers I get the warning “” failed to bind to material as they are instance proxies “path to/collisions/mesh_1/box” and proceeding to the next step of moving it using the physics inspector the robot arm and gripper is not recognizable and the dialog box says “Re-enable authoring”
I have followed the exact steps of the tutorial series.
Steps to Reproduce
  1. Finish Tutorial 6
  2. Tutorial 7: Adding physics and configuring joint effort limits
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
Hi @Asim_eng1, thank you for posting your issue. The problem is that the assets that are put together from Tutorial 6 have the prims as instanceable. In order to modify the prims or sub-prims properties you need to uncheck the instanceable property. Go to the properties panel for the collision prim and uncheck the instanceable checkbox. Then proceed with applying the material.
Hello!
We noticed that this topic hasn’t received any recent updates from anyone reporting this issue, so we are closing it for now to help keep the forum organized.
If you are still experiencing this issue or have related questions, please create a GitHub Discussion or Issue in the Isaac Sim repository and include a link to this topic along with updated details. Mentioning or linking to this original topic provides helpful context and makes it easier for others to assist you.
Best regards,
We have opened a ticket to improve the tutorial docs to avoid confusion in the future.
internal ticket: 6449903
Hi @Asim_eng1, we have made changes to the documentation for Isaac Sim tutorial and added instructions to change the asset instanceable property as explained above. These documentation changes will show up in Isaac Sim 6.1 which will be released first week of September.
