Hello!
I follow this tutorial jetson-inference/pytorch-ssd.md at master · dusty-nv/jetson-inference · GitHub and when I run
python3 onnx_export.py --model-dir=models/mymodel
, I get the following error:
Namespace(batch_size=1, height=300, input='', labels='labels.txt', model_dir='models/weeds', net='ssd-mobilenet', output='', width=300)
running on device cuda:0
found best checkpoint with loss 10000.000000 ()
creating network: ssd-mobilenet
num classes: 3
loading checkpoint: models/weeds/
File "onnx_export.py", line 86, in <module>
net.load(args.input)
File "/home/maria/jetson-inference/python/training/detection/ssd/vision/ssd/ssd.py", line 135, in load
self.load_state_dict(torch.load(model, map_location=lambda storage, loc: storage))
File "/usr/local/lib/python3.6/dist-packages/torch/serialization.py", line 594, in load
with _open_file_like(f, 'rb') as opened_file:
File "/usr/local/lib/python3.6/dist-packages/torch/serialization.py", line 230, in _open_file_like
return _open_file(name_or_buffer, mode)
File "/usr/local/lib/python3.6/dist-packages/torch/serialization.py", line 211, in __init__
super(_open_file, self).__init__(open(name, mode))
IsADirectoryError: [Errno 21] Is a directory: 'models/mymodel/'
How can I solve this problem?
Thank you!
