I have try to change net, by net = jetson.inference.detectNet(argv=[‘–model=/home/jetson-inference/python/training/detection/ssd/model/task_dif_pinces/ssd-mobilenet.onnx’, ‘–labels=~/jetson-inference/python/training/detection/ssd/model/task_dif_pinces/labels.txt’, ‘–input-blob=input_0’, ‘–output-cvg=scores’, ‘–output-bbox=boxes’])
But whene I try to run I have the error :
error: model file ‘/home/jetson-inference/python/training/detection/ssd/model/task_dif_pinces/ssd-mobilenet.onnx’ was not found.
if loading a built-in model, maybe it wasn’t downloaded before.
Run the Model Downloader tool again and select it for download:
$ cd <jetson-inference>/tools
$ ./download-models.sh
[TRT] detectNet – failed to initialize.
jetson.inference – detectNet failed to load network
And I have verify the existance of the file “ssd-mobilenet.onnx” in that model, it existe.
Is the model located at /home/jetson-inference/python/training/detection/ssd/model/task_dif_pinces/?
The error indicates that it cannot find the ONNX model in that folder.
Could you try to verify with the following command?
