Issue running the sgie model in deepstream 7.1
• Hardware Platform (Jetson / GPU) Jetson Orin NX
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) 6.2
• TensorRT Version
I have converted the .onnx file into engine file using tao-deploy running tensorRt 8.6.3 in my laptop . But then when I am using this engine file for my sgie in jetson orin where the tensorRt version is 10.3.0 the depstream project is not able to run.
I have attached the log files below:
i am trying to uninstall the tensort version 8.6.3 from tao-deploy docker container and pip installing tensorRt 10.3.0 version but i g the cmd is stuck over here and moving forward
this is the cuda version in my device:
When you change platforms or update the version of TensorRT, you need to regenerate the engine file.
Yes I am trying to update the TensorRt version in my device to make it match the tensorRt version of the Jetson.
I have uninstalled the previous version of tensorRt. an installing 10.3 verisong using pip but it is stuck here:
If you switch to a different platform, you also need to regenerate the engine file. And you can refer to our Guide to learn how to install tensorrt on your jetson.
