Hallo,
I’m not able to use the Nvidia driver for my wine games. While starting wine there are errors on starting up Xrandr. I’m using Ubuntu 14.10.
X.Org X Server 1.16.0
Kernel: 3.16.0-31
Driver 346.47
WINEDEBUG=+xrandr wíne ./Diablo3
trace:xrandr:X11DRV_XRandR_Init Found XRandR 1.4.
trace:xrandr:xrandr12_init_modes CRTC 0: mode 0x1c2, 1920x1080+0+0.
trace:xrandr:xrandr12_init_modes OUTPUT 0: name "DP-2".
err:winediag:xrandr12_init_modes Broken NVIDIA RandR detected, falling back to RandR 1.0. Please consider using the Nouveau driver instead.
trace:xrandr:xrandr10_init_modes XRandR: found 10 sizes.
trace:xrandr:xrandr10_init_modes - at 0: 1920x1080 (1 rates): 50 Hz
trace:xrandr:xrandr10_init_modes - at 1: 1680x1050 (1 rates): 51 Hz
trace:xrandr:xrandr10_init_modes - at 2: 1440x900 (1 rates): 52 Hz
trace:xrandr:xrandr10_init_modes - at 3: 1366x768 (1 rates): 53 Hz
trace:xrandr:xrandr10_init_modes - at 4: 1280x1024 (1 rates): 54 Hz
trace:xrandr:xrandr10_init_modes - at 5: 1280x800 (1 rates): 55 Hz
trace:xrandr:xrandr10_init_modes - at 6: 1280x720 (1 rates): 56 Hz
trace:xrandr:xrandr10_init_modes - at 7: 1024x768 (1 rates): 57 Hz
trace:xrandr:xrandr10_init_modes - at 8: 800x600 (1 rates): 58 Hz
trace:xrandr:xrandr10_init_modes - at 9: 640x480 (1 rates): 59 Hz
trace:xrandr:xrandr10_init_modes XRandR modes: count=10
trace:xrandr:xrandr10_init_modes Available DD modes: count=30
trace:xrandr:xrandr10_init_modes Enabling XRandR
There are some informations about this behaveiour:
http://wiki.winehq.org/FAQ#head-94de08f9ce3090e6f1152c71ce0cb35cbb03b42b
http://http.download.nvidia.com/XFree86/Linux-x86/1.0-9625/README/chapter-04.html
They are telling to modify xorg.conf, what I did like this, but no success until now:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 346.47 (buildmeister@swio-display-x86-rhel47-01) Thu Feb 19 19:18:25 PST 2015
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 346.47 (buildmeister@swio-display-x86-rhel47-01) Thu Feb 19 19:19:45 PST 2015
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LGD"
# 1920x1080 74.91 Hz (CVT 2.07M9) hsync: 84.64 kHz; pclk: 220.75 MHz
Modeline "1920x1080_75.00" 220.75 1920 2064 2264 2608 1080 1083 1088 1130 -hsync +vsync
HorizSync 83.0 - 83.0
VertRefresh 75.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 980M"
Option "DynamicTwinView" "FALSE"
Option "metamodes" "1920x1080"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "1920x1080_75 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
Modes "1920x1080_75"
EndSubSection
EndSection
The guides tell the output of xrandr --q1 should list only the native resolution like 1920x1080 in my case, but with all the modifications ion xorg.conf there are still 10 modes available:
xrandr --q1:
SZ: Pixels Physical Refresh
*0 1920 x 1080 ( 381mm x 211mm ) *50
1 1680 x 1050 ( 333mm x 205mm ) 51
2 1440 x 900 ( 285mm x 175mm ) 52
3 1366 x 768 ( 271mm x 150mm ) 53
4 1280 x 1024 ( 254mm x 200mm ) 54
5 1280 x 800 ( 254mm x 156mm ) 55
6 1280 x 720 ( 254mm x 140mm ) 56
7 1024 x 768 ( 203mm x 150mm ) 57
8 800 x 600 ( 158mm x 117mm ) 58
9 640 x 480 ( 127mm x 93mm ) 59
Current rotation - normal
Current reflection - none
Rotations possible - normal left inverted right
Reflections possible - X Axis Y Axis
xrandr -q:
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
1920x1080 75.0*+
HDMI-0 disconnected (normal left inverted right x axis y axis)
Unknown-0 disconnected (normal left inverted right x axis y axis)
Please let me know, what to do to avoid the xrandr fallback to nouveau driver.
Thanks for help.
Best regards
Kitsab
