i am new with dlib and the face detection modules.
Need to get php dlib module working for which a requirement is to install DLib as shared library so ad to complie it manually with apparent successes via:
git clone GitHub - davisking/dlib: A toolkit for making real world machine learning and data analysis applications in C++
cd dlib/dlib
mkdir build
cd build
cmake -DBUILD_SHARED_LIBS=ON …
make
sudo make install
sudo ldconfig
Then when run a php/python/cpp test via utility: GitHub - matiasdelellis/pdlib-min-test-suite: Minimum tests to ensure the operation of the facerecognition nextcloud app
Always getting the flowing error for all three methods:
Error while calling cudnnGetConvolutionForwardWorkspaceSize( context(), descriptor(data), (const cudnnFilterDescriptor_t)filter_handle, (const cudnnConvolutionDescriptor_t)conv_handle, descriptor(dest_desc), (cudnnConvolutionFwdAlgo_t)forward_algo, &forward_workspace_size_in_bytes) in file /home/nvjet/dlib/dlib/cuda/cudnn_dlibapi.cpp:1026. code: 9, reason: CUDNN_STATUS_NOT_SUPPORTED
Looking into Release Notes :: NVIDIA Deep Learning cuDNN Documentation found that this potentialy should have been resoved?
The functions cudnnGetConvolutionForwardAlgorithm_v7() and cudnnGetConvolutionForwardWorkspaceSize() may return CUDNN_STATUS_SUCCESS while the execution of the same convolution returns CUDNN_STATUS_NOT_SUPPORTED. Similar issues may also happen for convolutionBackwardData() and convolutionBackwardFilter(). This issue is present in cuDNN 7.2.2 library and later versions. This has been fixed in
cuDNN 8.0.0.
Current machine build details:
Using Jetpack 4.4.1 [L4T 32.4.4]
