It may be related to your v4l2loopback version.
It works in my case using 0.12.3 built with dkms such as Gstreamer v4l2loopback hw mjpeg stream - #5 by Honey_Patouceul. (this post was building 0.12.5).
I made RTSP server with test-launch:
./test-launch "videotestsrc ! nvvidconv ! nvv4l2h265enc insert-sps-pps=1 insert-vui=1 idrinterval=15 ! h265parse ! rtph265pay name=pay0"
Then installed v4l2loopback. Note that if you change format, framerate or else you may have to unload the module with rmmod and reinstall.
Then launched a pipeline connecting to RTSP server, decoding and sending to v4l2sink. Note that you would use identity with drop-allocation property set:
sudo rmmod v4l2loopback
sudo modprobe v4l2loopback
#My AGX had no camera, so the virtual node is video0
gst-launch-1.0 rtspsrc latency=0 location=rtsp://127.0.0.1:8554/test ! rtph265depay ! queue ! h265parse ! nvv4l2decoder ! nvvidconv ! videoconvert ! identity drop-allocation=1 ! v4l2sink device=/dev/video0
v4l2-ctl -d0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
and using the virtual video node works, although a bit slow:
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! autovideosink
The messages failed to open /dev/video4: No such file or directory
… are because you gave number 41 to your virtual node, but there are many available nodes with lower number. Probably using /dev/video4 for v4l2loopback would fix this.
