Issue with Stream Handling in Unstable Network Conditions
I am currently using the new Streammux configuration, which works correctly when both streams are running over a stable connection. However, when the connection becomes unstable, only one of the two streams remains functional, while the other stops working.
It is important to note that when each stream is run separately in its own pipeline, they both function properly, even under the same network conditions.
I would like to know how to ensure that both streams remain functional within the same pipeline, even when the connection is unstable—similar to the behavior observed when using local streams.
Thank you for your support.
    os.environ['USE_NEW_NVSTREAMMUX'] = 'yes'
    os.environ['NVSTREAMMUX_ADAPTIVE_BATCHING'] = 'yes'
    self.streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not self.streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    self.pipeline.add(self.streammux)
    batched_push_timeout=2560
    max_same_source_frames=85
    max_latency_ms = 500
    max_latency_us = max_latency_ms * 1000  # Convertir en microsecondes
    self.streammux.set_property("batch-size", self.number_sources)
    self.streammux.set_property("attach-sys-ts", True)
    self.streammux.set_property("sync-inputs", 0)
    self.streammux.set_property('max-latency', max_latency_us)
• Hardware Platform: GPU
• DeepStream Version 6.4
• TensorRT Version 8.6.1
• Issue Type questions,bugs
Can you upgrade to the latest DeepStream version? We have provided the reconnection scheme with deepstream-app and other samples for the unstable rtsp sources. The reconnection will not impact the stable streams.
