Hi all,
I’m having an issue with TensorFlow on the Jetson AGX Javier. I followed the following link procedure on downloading TensorFlow and even updated gast and kera_processing to the correct versions since the ones on the list are outdated: Installing TensorFlow for Jetson Platform :: NVIDIA Deep Learning Frameworks Documentation
This is the error I am getting when running my program:
Would someone be able to provide some clarification on the resolution to this Warning?
It seems that you meet a similar issue as below.
Based on the comment, would you mind to shift the import order of OpenCV and TensorFlow to see it it works?
https://github.com/opencv/opencv/issues/14884#issuecomment-599852128
Hi AastaLLL,
I really appreciate your comment thank you. I did not have OpenCV imported, but by further researching the answer you provided I was able to find a solution on the NVIDIA forums and StackOverflow. Here are the links for anyone curious about it in the future:
The answer was just to go to the terminal and type:
export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
That removed the error.
