Issues installing jetson-multimedia-api on Jetpack 5.1.2
I am currently running a NVIDIA Jetson Xavier AGX on Jetpack 5.1.2 and am running into issues installing the following packages:
nvidia-l4t-jetson-multimedia-api.
When I flash an NVIDIA Jetson Xavier AGX, I run into the following issues when trying to install nvidia-l4t-jetson-multimedia-api:
vs@logical-bid:~$ sudo apt install nvidia-l4t-jetson-multimedia-api
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 nvidia-l4t-jetson-multimedia-api : PreDepends: nvidia-l4t-core (< 35.2-0) but 35.3.1-20230319081403 is to be installed
                                    Depends: nvidia-l4t-camera (= 35.1.0-20220825113828) but 35.3.1-20230319081403 is to be installed
                                    Depends: nvidia-l4t-multimedia (= 35.1.0-20220825113828) but 35.3.1-20230319081403 is to be installed
                                    Depends: nvidia-l4t-multimedia-utils (= 35.1.0-20220825113828) but 35.3.1-20230319081403 is to be installed
E: Unable to correct problems, you have held broken packages.
In the past on when using Jetpack 4.6 on the Xavier AGX, I encountered no issues installing the multimedia API directly from apt.
Any insight into this issue would be very helpful.
Please make sure your system is in Jetpack 5.1.2(r35.4.1). Looks like certain packages are old. 35.1 is Jetpack 5.0.2 and 35.2 is Jetpack 5.1.
Would suggest re-flash the system through SDKManager and try again.
