Multimedia API install Error!
Hi
I’m setting up Jetson AGX Xavier using SDK Manager.
However, only Multimedia install fails.
The following error is output.
Please tell me the cause.
I bought an expensive one, but I get angry if I can’t move it.
Help me!
14:58:35 INFO: Multimedia API - target: Depends: nvidia-l4t-multimedia (= 32.7.2-20220417024839) but 32.7.1-20220219090344 is to be installed
14:58:35 INFO: Multimedia API - target: Depends: nvidia-l4t-multimedia-utils (= 32.7.2-20220417024839) but 32.7.1-20220219090344 is to be installed
14:58:35 ERROR: Multimedia API - target: E: Unable to correct problems, you have held broken packages.
14:58:35 ERROR: Multimedia API - target: Unhandled error when running sudo -E apt-get -y --allow-downgrades install /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_32.7.2-20220417024839_arm64.deb: E: Unable to correct problems, you have held broken packages.;
14:58:35 INFO: Multimedia API - target: [ Package Install Finished with Error ]
14:58:35 INFO: Multimedia API - target: [host] [ 24.00 KB used. Disk Avail: 155.32 GB ]
14:58:35 INFO: Multimedia API - target: [ NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP Install took 40s ]
14:58:35 ERROR: Multimedia API - target: command terminated with error
14:58:35 SUMMARY: Multimedia API - target: First Error: Installation failed. . Your device BSP image version is incompatible with the software version you are trying to install. Please flash your device with the right BSP version and try to re-install.
Hi uchida-k,
Please try below commands:
$ sudo apt update
$ sudo apt install nvidia-l4t-jetson-multimedia-api=32.7.1-20220219090344
Hi carolyuu,
I have successfully installed with the steps you taught me!
Thank you very much.
