Hi, I’ve downloaded the latest Jetson Nano image and created the SD card. When I’m running the SDKManager I get the error " SUMMARY: Multimedia API: Failed to install debian package [target]". I have re-imaged the SD Card and try again to find the same issue. Does anybody knows what is the problem? This is the log:
• 5:31:42 DEBUG: Multimedia API: using adapter to install NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP@JETSON_AGX_XAVIER to /home/media/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
• 15:31:42 INFO: Multimedia API: [ Disk Avail:189.04 GB ]
• 15:31:42 INFO: Multimedia API: Using GenericInstaller to Install NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP
• 15:31:42 INFO: Multimedia API: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP include 1 package
• 15:31:42 INFO: Multimedia API: [ Package Install Started ]
• 15:31:42 INFO: Multimedia API: target deb installer start to install
• 15:31:42 INFO: Multimedia API: exec_command: dpkg -f /home/media/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb Package | tr -d '\n'
• 15:31:42 INFO: Multimedia API: exec_command: dpkg -f /home/media/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb Version | tr -d '\n'
• 15:31:42 INFO: Multimedia API: deb file /home/media/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb, package name [nvidia-l4t-jetson-multimedia-api], package version [32.4.3-20200625213407]
• 15:31:42 INFO: Multimedia API: infer package info from file name nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb [ name: nvidia-l4t-jetson-multimedia-api, version: 32.4.3-20200625213407 ]
• 15:31:42 INFO: Multimedia API: exec_command [target]:
• 15:31:42 INFO: Multimedia API: **********************
• 15:31:42 INFO: Multimedia API: #!/bin/bash
• 15:31:42 INFO: Multimedia API: set -e
• 15:31:42 INFO: Multimedia API: export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
• 15:31:42 INFO: Multimedia API: sudo mkdir -p /opt/nvidia/deb_repos
• 15:31:42 INFO: Multimedia API: sudo chmod 777 /opt/nvidia/deb_repos
• 15:31:42 INFO: Multimedia API: sudo rm -f /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb
• 15:31:42 INFO: Multimedia API: [target] kaya@kaya's password:
• 15:31:43 INFO: Multimedia API: [target] kaya@kaya's password:
• 15:31:43 INFO: Multimedia API: [target] [sudo] password for kaya:
• 15:31:44 INFO: Multimedia API:
• 15:31:44 : Multimedia API: Warning: Permanently added 'kaya,10.0.0.59' (ECDSA) to the list of known hosts.
• 15:31:44 INFO: Multimedia API: [target] kaya@kaya's password:
• 15:31:48 INFO: Multimedia API: nvidia-l4t-jetson-multimedia-api_32.4.3-20200 0% 0 0.0KB/s --:-- ETA nvidia-l4t-jetson-multimedia-api_32.4.3-20200 28% 19MB 18.6MB/s 00:02 ETA nvidia-l4t-jetson-multimedia-api_32.4.3-20200 56% 38MB 18.7MB/s 00:01 ETA nvidia-l4t-jetson-multimedia-api_32.4.3-20200 81% 55MB 18.5MB/s 00:00 ETA nvidia-l4t-jetson-multimedia-api_32.4.3-20200 100% 67MB 18.2MB/s 00:03
• 15:31:48 INFO: Multimedia API: exec_command [target]:
• 15:31:48 INFO: Multimedia API: **********************
• 15:31:48 INFO: Multimedia API: #!/bin/bash
• 15:31:48 INFO: Multimedia API: set -e
• 15:31:48 INFO: Multimedia API: export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
• 15:31:48 INFO: Multimedia API: function safe_apt_install {
• 15:31:48 INFO: Multimedia API: echo "*begin $1, $2"
• 15:31:48 INFO: Multimedia API: tmp_log=/tmp/jetpack_dpkg_log.txt
• 15:31:48 INFO: Multimedia API: sudo rm -f $tmp_log
• 15:31:48 INFO: Multimedia API: set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
• 15:31:48 INFO: Multimedia API: while [ ${CMD_STATUS} -ne 0 ]; do
• 15:31:48 INFO: Multimedia API: if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
• 15:31:48 INFO: Multimedia API: echo "Waiting $2 seconds for apt to be available"; sleep ${2}
• 15:31:48 INFO: Multimedia API: else
• 15:31:48 INFO: Multimedia API: echo "Unhandled error when running $1"; exit 1
• 15:31:48 INFO: Multimedia API: fi
• 15:31:48 INFO: Multimedia API: done
• 15:31:48 INFO: Multimedia API: }
• 15:31:48 INFO: Multimedia API: safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb" 5
• 15:31:48 INFO: Multimedia API: sleep 5
• 15:31:48 INFO: Multimedia API: sudo rm -f /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb
• 15:31:48 INFO: Multimedia API: [target] kaya@kaya's password:
• 15:31:49 INFO: Multimedia API: [target] kaya@kaya's password:
• 15:31:49 INFO: Multimedia API: *begin sudo dpkg -i /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb, 5
• 15:31:50 INFO: Multimedia API: [target] [sudo] password for kaya:
• 15:31:50 INFO: Multimedia API: (Reading database ... 141324 files and directories currently installed.)
• 15:31:50 INFO: Multimedia API: Preparing to unpack .../nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb ...
• 15:31:50 INFO: Multimedia API: Unpacking nvidia-l4t-jetson-multimedia-api (32.4.3-20200625213407) over (32.4.3-20200625213407) ...
• 15:32:22 INFO: Multimedia API: dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-multimedia-api:
• 15:32:22 INFO: Multimedia API: nvidia-l4t-jetson-multimedia-api depends on nvidia-l4t-camera (= 32.4.3-20200625213407); however:
• 15:32:22 INFO: Multimedia API: Version of nvidia-l4t-camera on system is 32.4.3-20200625213809.
• 15:32:22 INFO: Multimedia API: nvidia-l4t-jetson-multimedia-api depends on nvidia-l4t-multimedia (= 32.4.3-20200625213407); however:
• 15:32:22 INFO: Multimedia API: Version of nvidia-l4t-multimedia on system is 32.4.3-20200625213809.
• 15:32:22 INFO: Multimedia API: nvidia-l4t-jetson-multimedia-api depends on nvidia-l4t-multimedia-utils (= 32.4.3-20200625213407); however:
• 15:32:22 INFO: Multimedia API: Version of nvidia-l4t-multimedia-utils on system is 32.4.3-20200625213809.
• 15:32:22 INFO: Multimedia API: dpkg: error processing package nvidia-l4t-jetson-multimedia-api (--install):
• 15:32:22 INFO: Multimedia API: dependency problems - leaving unconfigured
• 15:32:22 INFO: Multimedia API: Errors were encountered while processing:
• 15:32:22 INFO: Multimedia API: Unhandled error when running sudo dpkg -i /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_32.4.3-20200625213407_arm64.deb
• 15:32:22 INFO: Multimedia API: [ Package Install Finished with Error ]
• 15:32:22 INFO: Multimedia API: [ 16.00 KB used. Disk Avail: 189.04 GB ]
• 15:32:22 INFO: Multimedia API: [ NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP Install took 39s ]
• 15:32:22 SUMMARY: Multimedia API: Failed to install debian package [target]
