Issues launching Chromium-based browsers (Brave/Chromium) on Jetson Orin NX 8GB – JetPack 6.0
I am experiencing issues launching Chromium-based browsers on my Jetson Orin NX 8GB module running JetPack 6.0.
Problem Description: I have attempted to install both Brave and Chromium, but neither application will initialize. There are no visible error pop-ups or windows; the applications simply fail to open after the launch command is issued.
Steps Taken:
  1. Brave Browser: Installed via the default Software Center GUI. The installation completed successfully, but the app does not open.
  2. Chromium: Installed via terminal using sudo apt install -y chromium-browser. The package installed without errors, but the browser fails to launch.
Environment:
  • Hardware: Jetson Orin NX 8GB
  • Software: JetPack 6.0 (L4T 36.x)
  • OS: Ubuntu 22.04 LTS
Could you please provide the recommended or “optimal” method for installing and running a stable Chrome-based browser on this specific JetPack 6 configuration? Are there specific flags or GPU-acceleration environment variables required for Chromium to run on the Orin NX?
Thank you for your assistance.
See:
https://forums.developer.nvidia.com/t/chromium-other-browsers-not-working-after-flashing-or-updating-heres-why-and-quick-fix/338891
Thanks inuxdev for the quick suggestion. This should be a known issue and also listed in
Making sure you're not a bot!
