Recommended/supported web browser to install
Good day, What is the best supported web browser for the Jetson AGX Orin unit - I’ve tried both the Firefox and Brave browsers, they install - but they fail to launch ?
Trying this next … https://askubuntu.com/questions/187888/what-is-the-correct-way-to-completely-remove-an-application
TRIED THIS (2025/11/10 - 11:21)
kopbeen@jetson-host:/media/kopbeen/steek2_0/dusty-nv$ brave-browser --no-sandbox
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
[9631:9631:1110/112051.584807:ERROR:chrome/browser/process_singleton_posix.cc:358] The profile appears to be in use by another Brave process (3826) on another computer (ubuntu). Brave has locked the profile so that it doesn’t get corrupted. If you are sure that no other processes are using this profile, you can unlock the profile and relaunch Brave.
[9631:9631:1110/112051.584956:ERROR:chrome/browser/ui/views/message_box_dialog.cc:199] Unable to show message box: Brave - The profile appears to be in use by another Brave process (3826) on another computer (ubuntu). Brave has locked the profile so that it doesn’t get corrupted. If you are sure that no other processes are using this profile, you can unlock the profile and relaunch Brave.
→ running a top command and there is no process id for another Brave process (3826)
The question about the best supported web browser for the Jetson AGX Orin unit is unrelated to the provided context, which focuses on the Fakra camera connection with the Orin AGX and the Jetson AGX Xavier.
However, I can provide a general answer based on common knowledge about the Jetson AGX Orin. The Jetson AGX Orin is a powerful embedded system designed for edge computing and robotics applications. While it’s not explicitly stated in the provided context, the recommended web browser for the Jetson AGX Orin is likely to be a lightweight and Linux-compatible browser.
Based on the information provided, you’ve tried installing Firefox and Brave browsers, but they failed to launch. This could be due to various reasons such as compatibility issues, dependencies, or configuration problems.
To resolve the issue, you can try the following:
  1. Check the system requirements and compatibility of the browsers with the Jetson AGX Orin’s operating system.
  2. Ensure that all dependencies are installed and up-to-date.
  3. Try removing and reinstalling the browsers using the correct package manager commands.
  4. Consider using a lightweight browser such as Chromium or Midori, which might be more compatible with the Jetson AGX Orin’s resources.
Regarding the link you provided (https://askubuntu.com/questions/187888/what-is-the-correct-way-to-completely-remove-an-application), it’s a general guide on how to completely remove an application on Ubuntu-based systems. You can follow the instructions to remove the browsers and try reinstalling them.
In comparison to other browsers, Chromium is often recommended for Linux-based systems due to its lightweight nature and compatibility. However, without more specific information about the Jetson AGX Orin’s configuration and operating system, it’s difficult to provide a definitive answer.
In summary, the best supported web browser for the Jetson AGX Orin unit is likely to be a lightweight and Linux-compatible browser such as Chromium. However, more information about the system configuration and operating system is required to provide a more specific answer.
Hi again - unfortunately none of the browser launch successfully - guess I need to reflash again ..
Please refer to Chromium, other browsers not working after flashing or updating - Here's WHY and QUICK FIX to see if can work.
Thank you, I will have a look - see
Pieter Claassens
Software Engineer
SHOCK Electro-Optic Systems
Cell: +27 83 561 8577
WhatsApp: +27 68 742 8101
Thank you very much @kaycc - works like a charm !
