Issues on using Retail Object Detection as the pre-trained weights
Hi, I’m facing two issues when I tried to use the Nvidia Retail Object Detection as the pre-trained weights:
  1. I’m not able to use multi gpus
  2. with --gpus 1, it could complete the first epoch, but failed in the beginning of the second epoch. seems out of memory…
Any suggestions would be greatly appreciated. Thanks!
• Machine: GCP Vertex Notebook (Debian 10 + python 3.7 + Driver Version: 510.47.03 + CUDA Version: 11.6)
• Hardware: V100 x 2
• Network Type: EfficientDet TF2
• TLT Version: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf2.9.1
• Training spec file
data:
  loader:
    prefetch_size: 4
    shuffle_file: True
  max_instances_per_image: 100
  skip_crowd_during_training: True
  image_size: '640x640'
  num_classes: 4
  train_tfrecords:
    - '/workspace/efficientdet/tfrecords/train/train-*'
  val_tfrecords:
    - '/workspace/efficientdet/tfrecords/val/val-*'
  val_json_file: '/workspace/efficientdet/datasets/ap_od_03292023_val/labels.json'
train:
  optimizer:
    momentum: 0.9
  lr_schedule:
    warmup_epoch: 5
    warmup_init: 0.0001
    learning_rate: 0.2
  amp: True
  checkpoint: "/workspace/efficientdet/efficientdet-d5_038.tlt"
  num_examples_per_epoch: 26972
  moving_average_decay: 0.999
  batch_size: 1
  checkpoint_interval: 10
  l2_weight_decay: 0.00004
  l1_weight_decay: 0.0
  clip_gradients_norm: 10.0
  image_preview: True
  qat: False
  random_seed: 42
  pruned_model_path: ''
  num_epochs: 200
model:
  aspect_ratios: '[(1.0, 1.0), (1.4, 0.7), (0.7, 1.4)]'
  anchor_scale: 4
  min_level: 3
  max_level: 7
  num_scales: 3
  freeze_bn: False
  freeze_blocks: []
augment:
  rand_hflip: True
  random_crop_min_scale: 0.1
  random_crop_max_scale: 2
  auto_color_distortion: False
  auto_translate_xy: True
evaluate:
  batch_size: 1
  num_samples: 4391
  max_detections_per_image: 100
  model_path: ''
export:
  max_batch_size: 8
  dynamic_batch_size: True
  min_score_thresh: 0.4
  model_path: ""
  output_path: ""
inference:
  model_path: ""
  image_dir: ""
  output_dir: ""
  dump_label: False
  batch_size: 1
prune:
  model_path: ""
  normalizer: 'max'
  output_path: ""
  equalization_criterion: 'union'
  granularity: 8
  threshold: 0.5
  min_num_filters: 16
  excluded_layers: []
key: 'nvidia-tlt'
results_dir: '/workspace/efficientdet/experiment_dir_unpruned'
• How to reproduce the issue ?
  • command:
docker run -it --rm --gpus all -v /home/jupyter:/workspace --shm-size=32gb nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf2.9.1 efficientdet_tf2 train -e /workspace/efficientdet/specs/train.yaml --gpus 1
  • multi gpus error log:
        class-3-bn-4 (BatchNormalizati  (None, 40, 40, 288)  1152       ['class-3[1][0]']
 on)        class-3-bn-5 (BatchNormalizati  (None, 20, 20, 288)  1152       ['class-3[2][0]']        on)
 class-3-bn-6 (BatchNormalizati  (None, 10, 10, 288)  1152       ['class-3[3][0]']        on)        class-3-bn-7 (BatchNormalizati  (None, 5, 5, 288)   1152        ['class-3[4][0]']
 on)
        box-3-bn-3 (BatchNormalization  (None, 80, 80, 288)  1152       ['box-3[0][0]']        )
 box-3-bn-4 (BatchNormalization  (None, 40, 40, 288)  1152       ['box-3[1][0]']
 )        box-3-bn-5 (BatchNormalization  (None, 20, 20, 288)  1152       ['box-3[2][0]']        )
 box-3-bn-6 (BatchNormalization  (None, 10, 10, 288)  1152       ['box-3[3][0]']        )        box-3-bn-7 (BatchNormalization  (None, 5, 5, 288)   1152        ['box-3[4][0]']
        activation_59 (Activation)     (None, 80, 80, 288)  0           ['class-3-bn-3[0][0]']        activation_63 (Activation)     (None, 40, 40, 288)  0           ['class-3-bn-4[0][0]']
 activation_67 (Activation)     (None, 20, 20, 288)  0           ['class-3-bn-5[0][0]']        activation_71 (Activation)     (None, 10, 10, 288)  0           ['class-3-bn-6[0][0]']
 activation_75 (Activation)     (None, 5, 5, 288)    0           ['class-3-bn-7[0][0]']
        activation_79 (Activation)     (None, 80, 80, 288)  0           ['box-3-bn-3[0][0]']        activation_83 (Activation)     (None, 40, 40, 288)  0           ['box-3-bn-4[0][0]']
 activation_87 (Activation)     (None, 20, 20, 288)  0           ['box-3-bn-5[0][0]']        activation_91 (Activation)     (None, 10, 10, 288)  0           ['box-3-bn-6[0][0]']
 activation_95 (Activation)     (None, 5, 5, 288)    0           ['box-3-bn-7[0][0]']
 class-predict (SeparableConv2D  multiple            12996       ['activation_59[0][0]',
 )        'activation_63[0][0]',
        'activation_67[0][0]',
        'activation_71[0][0]',
        'activation_75[0][0]']
 box-predict (SeparableConv2D)  multiple             12996       ['activation_79[0][0]',
        'activation_83[0][0]',
        'activation_87[0][0]',
        'activation_91[0][0]',
        'activation_95[0][0]']        ==================================================================================================        Total params: 33,657,021
Trainable params: 33,429,629
Non-trainable params: 227,392        __________________________________________________________________________________________________        LR schedule method: cosine        Use SGD optimizer
/usr/local/lib/python3.8/dist-packages/keras/backend.py:450: UserWarning: `tf.keras.backend.set_learning_phase` is deprecated and will be removed after 2020-10-11. T
o update it, simply pass a True/False value to the `training` argument of the `__call__` method of your layer or model.                                                warnings.warn('`tf.keras.backend.set_learning_phase` is deprecated and '        WARNING:tensorflow:`period` argument is deprecated. Please use `save_freq` to specify the frequency in number of batches seen.                                      `period` argument is deprecated. Please use `save_freq` to specify the frequency in number of batches seen.
`period` argument is deprecated. Please use `save_freq` to specify the frequency in number of batches seen.                                                          Epoch 1/200        /usr/local/lib/python3.8/dist-packages/keras/backend.py:450: UserWarning: `tf.keras.backend.set_learning_phase` is deprecated and will be removed after 2020-10-11. To update it, simply pass a True/False value to the `training` argument of the `__call__` method of your layer or model.
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f89f00b0e50> and will run it as-is.                Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f89f00b0e50>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f89f00b0670> and will run it as-is.          Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f89f00b0670>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f6534255430> and will run it as-is.                Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f6534255430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain th
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f655b1dc8b0> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f655b1dc8b0>. Note that functions defined in certai
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f655b1dc8b0>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code                          To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f88be7adaf0> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f88be7adaf0>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code                                To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f88be7adee0> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f88be7adee0>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code                          To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f655ac5ce50> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f655ac5ce50>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code                                To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f655ab83430> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f655ab83430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code                          To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 1 with PID 0 on node 30fb12a8e965 exited on signal 9 (Killed).
Sending telemetry data.
Telemetry data couldn't be sent, but the command ran successfully.
[Error]: <urlopen error [Errno -2] Name or service not known>
Execution status: FAIL
  • epoch 2 error log:
activation_58 (Activation)     (None, 80, 80, 288)  0           ['class-2-bn-3[0][0]']
activation_62 (Activation)     (None, 40, 40, 288)  0           ['class-2-bn-4[0][0]']
activation_66 (Activation)     (None, 20, 20, 288)  0           ['class-2-bn-5[0][0]']
activation_70 (Activation)     (None, 10, 10, 288)  0           ['class-2-bn-6[0][0]']
activation_74 (Activation)     (None, 5, 5, 288)    0           ['class-2-bn-7[0][0]']
activation_78 (Activation)     (None, 80, 80, 288)  0           ['box-2-bn-3[0][0]']
activation_82 (Activation)     (None, 40, 40, 288)  0           ['box-2-bn-4[0][0]']
activation_86 (Activation)     (None, 20, 20, 288)  0           ['box-2-bn-5[0][0]']
activation_90 (Activation)     (None, 10, 10, 288)  0           ['box-2-bn-6[0][0]']
activation_94 (Activation)     (None, 5, 5, 288)    0           ['box-2-bn-7[0][0]']
class-3 (SeparableConv2D)      multiple             85824       ['activation_58[0][0]',
        'activation_62[0][0]',
        'activation_66[0][0]',
        'activation_70[0][0]',
        'activation_74[0][0]']
box-3 (SeparableConv2D)        multiple             85824       ['activation_78[0][0]',
        'activation_82[0][0]',
        'activation_86[0][0]',
        'activation_90[0][0]',
        'activation_94[0][0]']
class-3-bn-3 (BatchNormalizati  (None, 80, 80, 288)  1152       ['class-3[0][0]']
on)
on)
on)
on)
on)
Use SGD optimizer
Epoch 1/200
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7fac1430e430> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7fac1430e430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7fac4da988b0> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7fac4da988b0>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7fac4d557e50> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7fac4d557e50>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7fac4d4fc430> and will run it as-is.
Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7fac4d4fc430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
6/26972 [..............................] - ETA: 3:59:32 - det_loss: 1.3752 - cls_loss: 0.6926 - box_loss: 0.0137 - reg_l2_loss: 0.2557 - reg_l1_loss: 0.0000e+00
- loss: 1.6308 - learning_rate: 1.0371e-04 - gradient_norm: nanWARNING:tensorflow:Callback method `on_train_batch_end` is slow compared to the batch time (batch time: 0.5248s vs `on_train_batch_end` time: 3.8910s). Check your callbacks.
26972/26972 [==============================] - ETA: 0s - det_loss: 0.8992 - cls_loss: 0.4544 - box_loss: 0.0089 - reg_l2_loss: 0.2541 - reg_l1_loss: 0.0000e+00 - loss: 1.1534 - learning_rate: 0.0201 - gradient_norm: nanNone
26972/26972 [==============================] - 11382s 403ms/step - det_loss: 0.8992 - cls_loss: 0.4544 - box_loss: 0.0089 - reg_l2_loss: 0.2541 - reg_l1_loss: 0.0000e+00 - loss: 1.1534 - learning_rate: 0.0201 - gradient_norm: nan - val_det_loss: 0.7016 - val_cls_loss: 0.3337 - val_box_loss: 0.0074 - val_loss: 0.9463
Epoch 2/200
2088/26972 [=>............................] - ETA: 2:40:13 - det_loss: 0.8325 - cls_loss: 0.3928 - box_loss: 0.0088 - reg_l2_loss: 0.2435 - reg_l1_loss: 0.0000e+00
- loss: 1.0760 - learning_rate: 0.0416 - gradient_norm: 1.3853Killed
Could you try below?
docker run --runtime=nvidia -it --rm --gpus all -v /home/jupyter:/workspace --shm-size=32gb nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf2.9.1 efficientdet_tf2 train -e /workspace/efficientdet/specs/train.yaml --gpus 1
not working. same issue. I think --gpus all already uses the nvidia runtime.
error log:
Epoch 1/300WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f705c591430> and will run it as-is.                Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f705c591430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f705c591430> and will run it as-is.                                   Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f705c591430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f708c5588b0> and will run it as-is.          Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f708c5588b0>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f708c5588b0> and will run it as-is.                             Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f708c5588b0>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f7075f9ce50> and will run it as-is.                Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f7075f9ce50>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._update at 0x7f7075f9ce50> and will run it as-is.                                   Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._update at 0x7f7075f9ce50>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        WARNING:tensorflow:AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f7075ec1430> and will run it as-is.          Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f7075ec1430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code
To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        AutoGraph could not transform <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f7075ec1430> and will run it as-is.                             Cause: Unable to locate the source code of <function HvdMovingAverage.update_average.<locals>._apply_moving at 0x7f7075ec1430>. Note that functions defined in certain environments, like the interactive Python shell, do not expose their source code. If that is the case, you should define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.experimental.do_not_convert. Original error: could not get source code                             To silence this warning, decorate the function with @tf.autograph.experimental.do_not_convert        6/26972 [..............................] - ETA: 3:39:29 - det_loss: 1.0984 - cls_loss: 0.5159 - box_loss: 0.0117 - reg_l2_loss: 0.2557 - reg_l1_loss: 0.0000e+00 - loss: 1.3541 - learning_rate: 1.0371e-04 - gradient_norm: 10.0000WARNING:tensorflow:Callback method `on_train_batch_end` is slow compared to the batch time (batch time: 0.4799s vs `on_train_batch_end` time: 4.1284s). Check your callbacks.Callback method `on_train_batch_end` is slow compared to the batch time (batch time: 0.4799s vs `on_train_batch_end` time: 4.1284s). Check your callbacks.           26972/26972 [==============================] - ETA: 0s - det_loss: 0.9064 - cls_loss: 0.4599 - box_loss: 0.0089 - reg_l2_loss: 0.2546 - reg_l1_loss: 0.0000e+00 - loss: 1.1610 - learning_rate: 0.0201 - gradient_norm: nanNone
26972/26972 [==============================] - 11935s 422ms/step - det_loss: 0.9064 - cls_loss: 0.4599 - box_loss: 0.0089 - reg_l2_loss: 0.2546 - reg_l1_loss: 0.0000e+00 - loss: 1.1611 - learning_rate: 0.0201 - gradient_norm: nan - val_det_loss: 0.6999 - val_cls_loss: 0.3439 - val_box_loss: 0.0071 - val_loss: 0.9462
Epoch 2/300
 1858/26972 [=>............................] - ETA: 2:50:18 - det_loss: 0.8381 - cls_loss: 0.3934 - box_loss: 0.0089 - reg_l2_loss: 0.2459 - reg_l1_loss: 0.0000e+00 - loss: 1.0840 - learning_rate: 0.0415 - gradient_norm: 1.3892
error log from gcp:
Jun 29 13:28:17 zhongjin-ap-od-training-nvidia-retail-od cron[1400]: /usr/sbin/sendmail: Cannot allocate memory\r\n
Please try to set a lower learning rate, for example learning_rate: 0.1.
And set smaller clip_gradients_norm: 5.0
still not working, same error. I also tried smaller image size 416x416. and I downloaded the updated pre-trained weights from here. the issue persists.
Could you retry with small part of the training dataset instead?
Please change to below.
prefetch_size: 1
shuffle_file: false
Please set lower value for L2. l2_weight_decay: 0.000004
Please set amp:false as well.
I changed to use the validation set (4391 images) as the training set, it seems working, finished a few epochs. I’m curious about the dataset size limit if you have a rough number. Is there a plan to optimize the memory using?
Could you please modify the parameters mentioned above and retry the entire dataset? It will optimize the memory.
I tried. still OOM. I also verified that if I reduce the train set size, I can then use multiple gpus.
OK, when it is running successfully, how many training images and validation images? And how about the result of $nvidia-smi ?
Maybe there are issue in training images? Are there any corrupt or different kinds of image? Suggest to use part of training images to narrow down.
