Hi, @Morganh. Re-running everything I got to the same point. Still stuck =/
root@a4416cb5896d:/workspace/tao-experiments/efficientdet# efficientdet train -e /workspace/tao-experiments/efficientdet/specs/efficientdet_d0_retrain.txt -d /workspace/tao-experiments/efficientdet/experiment_dir_retrain/ -k nvidia_tlt --gpus 1 --gpu_index 1
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
Loading experiment spec at %s. /workspace/tao-experiments/efficientdet/specs/efficientdet_d0_retrain.txt
2022-06-29 15:57:31,548 [INFO] iva.efficientdet.utils.spec_loader: Merging specification from /workspace/tao-experiments/efficientdet/specs/efficientdet_d0_retrain.txt
2022-06-29 15:57:31,984 [INFO] iva.common.logging.logging: Log file already exists at /workspace/tao-experiments/efficientdet/experiment_dir_retrain/status.json
2022-06-29 15:57:31,984 [INFO] root: Starting EfficientDet training.
2022-06-29 15:57:31,985 [INFO] root: [train] AMP is activated - Experiment Feature
2022-06-29 15:57:31,986 [INFO] root: Create EncryptCheckpointSaverHook.
2022-06-29 15:57:31,986 [INFO] root: Loading pretrained model...
2022-06-29 15:57:45,497 [INFO] root: Starting training cycle: 1, epoch: 0.
Model: "model"
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
Input (InputLayer) [(16, 512, 512, 3)] 0
stem_conv_pad (ZeroPadding2D) (16, 513, 513, 3) 0 Input[0][0]
box-predict (SeparableConv2D) multiple 2916 activation_41[0][0]
activation_44[0][0]
activation_47[0][0]
activation_50[0][0]
activation_53[0][0]
Total params: 3,891,284
Trainable params: 3,845,428
Non-trainable params: 45,856
Pruned graph is loaded succesfully.
2022-06-29 15:57:51,949 [INFO] iva.efficientdet.models.det_model_fn: LR schedule method: cosine
2022-06-29 15:57:52,264 [INFO] iva.efficientdet.models.det_model_fn: clip gradients norm by 5.000000
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [current_loss_scale]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [good_steps]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block4b_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block4c_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block6a_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block6c_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block6d_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [weighted_fusion_0_0/weighted_fusion_0_0/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [class-1-bn-6/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block2b_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block3a_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block4c_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block5b_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [box-0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [class-0-bn-7/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,016 [WARNING] root: Checkpoint is missing variable [block2b_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block3a_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block4b_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block6b_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block1a_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [box-0-bn-5/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block6d_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn0_1_9_0_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn0_2_10_0_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [class-0-bn-3/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [box-0-bn-3/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block3b_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block5a_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block5c_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block6b_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block6c_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [block7a_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,017 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block6d_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [box-2-bn-4/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block5b_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [class-0-bn-4/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [class-2-bn-6/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block3b_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block4a_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [bifpn0_2_6_0_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [bifpn0_1_7_0_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [weighted_fusion_1_1/weighted_fusion_1_1/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block2a_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block2b_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block4c_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block5a_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block6c_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block6d_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [box-0-bn-5/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block4b_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block5a_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [block6b_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,018 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [class-predict/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block4c_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block6a_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block7a_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [class-2-bn-3/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block4b_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block6c_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block5a_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block6c_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block6d_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block7a_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block2b_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block3a_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block4c_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [p6_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [box-0-bn-5/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block5c_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [class-2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block4a_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,019 [WARNING] root: Checkpoint is missing variable [block5a_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [box-2-bn-5/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block1a_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block4c_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block5a_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block6d_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [stem_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block5b_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [class-1-bn-6/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [weighted_fusion_3_2/weighted_fusion_3_2/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block6d_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [bifpn0_0_8_0_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [box-0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [box-0-bn-3/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block5a_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block5b_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block6b_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [class-0-bn-5/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [class-2-bn-7/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block4a_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,020 [WARNING] root: Checkpoint is missing variable [block7a_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [bifpn0_2_6_0_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block3a_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block6d_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block7a_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [class-1-bn-6/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [class-2-bn-6/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block3b_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block3b_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [box-0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [class-1-bn-5/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block5c_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block6c_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block2a_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,021 [WARNING] root: Checkpoint is missing variable [block6d_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [bifpn0_2_6_0_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [weighted_fusion_1_2/weighted_fusion_1_2/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block1a_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block2a_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block4b_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block5a_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block5b_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block7a_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [class-predict/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block2a_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block2b_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block6a_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [p6/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [weighted_fusion_7_0/weighted_fusion_7_0/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [box-1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block1a_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block2a_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [block4a_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,022 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [class-2-bn-3/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [class-2-bn-5/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [box-2-bn-3/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block5c_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block6a_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block1a_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block4a_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block4b_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [box-0-bn-4/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [bifpn0_0_8_0_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [box-1-bn-5/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [box-2-bn-6/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block1a_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block2a_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block2b_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block4a_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [block6a_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [bifpn0_2_10_0_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,023 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [weighted_fusion_4_1/weighted_fusion_4_1/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block1a_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block4b_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block5b_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block6b_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block7a_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [bifpn0_1_9_0/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [weighted_fusion_2_1/weighted_fusion_2_1/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [class-0-bn-6/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [box-0-bn-7/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [class-0-bn-6/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block6c_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block2b_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [box-1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [class-1-bn-4/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [class-2-bn-5/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block2b_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block3a_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block3a_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block3b_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block4a_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,024 [WARNING] root: Checkpoint is missing variable [block7a_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [class-predict/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block2b_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block4c_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [weighted_fusion_7_2/weighted_fusion_7_2/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [class-0-bn-5/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [box-2-bn-7/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block4c_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block5b_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [box-2-bn-4/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block4c_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block2b_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [p6_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block3a_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block6c_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [weighted_fusion_3_0/weighted_fusion_3_0/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [weighted_fusion_4_0/weighted_fusion_4_0/ExponentialMovingAverage]
2022-06-29 15:58:17,025 [WARNING] root: Checkpoint is missing variable [block2a_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block6b_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block6d_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [class-1-bn-5/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block2b_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block6c_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [weighted_fusion_5_0/weighted_fusion_5_0/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block5a_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block5c_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block6a_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block7a_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block3b_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block4c_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block5b_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [box-0-bn-4/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [box-2-bn-6/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block5a_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,026 [WARNING] root: Checkpoint is missing variable [block5c_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [bifpn0_1_7_0_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [class-0-bn-4/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [block3b_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [block4a_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [block6b_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [block6d_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [weighted_fusion_3_1/weighted_fusion_3_1/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [class-0-bn-7/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [box-0-bn-6/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [class-2-bn-4/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [box-2-bn-4/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [block2a_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [class-0-bn-7/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [class-2-bn-4/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [stem_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [block6b_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [weighted_fusion_0_2/weighted_fusion_0_2/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [bifpn0_2_10_0_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [class-0-bn-3/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [box-1-bn-4/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,027 [WARNING] root: Checkpoint is missing variable [box-2-bn-6/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [block5a_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [block6b_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [box-1-bn-5/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [block4b_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [block3b_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [block4a_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [bifpn0_2_6_0/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [bifpn0_1_9_0_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [box-1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [class-1-bn-5/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [block6a_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [class-0-bn-4/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [box-1-bn-7/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [block2a_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [weighted_fusion_7_1/weighted_fusion_7_1/ExponentialMovingAverage]
2022-06-29 15:58:17,028 [WARNING] root: Checkpoint is missing variable [weighted_fusion_6_2/weighted_fusion_6_2/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block1a_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block3b_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block2a_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block6c_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block7a_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [bifpn0_1_7_0_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [box-2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block1a_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block4b_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block6a_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [bifpn0_0_8_0_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block4a_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [box-0-bn-3/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [box-2-bn-5/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,029 [WARNING] root: Checkpoint is missing variable [block4c_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [box-1-bn-4/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [box-2-bn-5/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [box-1-bn-7/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [box-0-bn-7/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [class-2-bn-7/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [block2a_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [block5c_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [block6d_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [weighted_fusion_5_1/weighted_fusion_5_1/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [box-1-bn-6/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [box-1-bn-7/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [class-2-bn-7/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [block1a_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [block2a_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [block2a_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [box-0-bn-6/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [class-2-bn-4/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,030 [WARNING] root: Checkpoint is missing variable [block2a_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [bifpn0_2_10_0/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [weighted_fusion_2_2/weighted_fusion_2_2/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block2b_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block6a_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block4a_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block4c_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [weighted_fusion_6_0/weighted_fusion_6_0/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block2b_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [box-1-bn-3/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block4b_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [box-1-bn-6/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block2b_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block4c_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block6a_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block6c_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block6b_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block5c_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,031 [WARNING] root: Checkpoint is missing variable [block3a_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block6a_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block7a_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [bifpn0_2_6_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [class-0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [box-0-bn-4/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block3a_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block3b_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block4c_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block5a_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block5b_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [bifpn0_1_9_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block3a_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block6b_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [class-2-bn-5/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block7a_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block2a_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block2b_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,032 [WARNING] root: Checkpoint is missing variable [block5b_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [bifpn_bn_6_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [class-1-bn-4/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [box-1-bn-6/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [box-2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [box-0-bn-7/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [block5b_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [block6a_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [bifpn0_1_7_0/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [class-0-bn-6/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [box-2-bn-3/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [box-predict/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [block3a_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [block6a_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [block6c_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,033 [WARNING] root: Checkpoint is missing variable [box-0-bn-5/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [block3a_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [block3b_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [bifpn0_2_6_0_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [box-0-bn-3/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [class-1-bn-3/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [block6c_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,034 [WARNING] root: Checkpoint is missing variable [class-0-bn-6/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [stem_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [block5c_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [weighted_fusion_2_0/weighted_fusion_2_0/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [weighted_fusion_0_1/weighted_fusion_0_1/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [class-0-bn-5/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [box-2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [class-2-bn-7/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [block5a_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [box-2-bn-4/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,035 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [stem_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block3b_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block5a_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block5b_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block4b_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block4a_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block4a_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block4b_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [bifpn0_1_7_0_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [class-1-bn-7/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block3b_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block6b_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,036 [WARNING] root: Checkpoint is missing variable [block6c_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block6d_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block4b_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block2a_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block5c_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_1_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [class-1/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [box-2-bn-7/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block5c_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [class-0-bn-5/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block5c_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [bifpn0_2_10_0_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_2/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [class-2-bn-3/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [class-2-bn-6/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block4a_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,037 [WARNING] root: Checkpoint is missing variable [block4b_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block2b_expand_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block3a_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [class-0-bn-7/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [box-1-bn-3/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [box-2-bn-3/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [box-2-bn-7/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [class-2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [box-0-bn-4/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block2b_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [weighted_fusion_4_2/weighted_fusion_4_2/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [class-0-bn-3/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block3b_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block7a_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [class-1-bn-7/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block5c_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block4b_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [bifpn0_0_8_0_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,038 [WARNING] root: Checkpoint is missing variable [block6a_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block4a_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block5b_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block7a_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [bifpn0_1_9_0_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block4a_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block3b_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block4b_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block4c_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block7a_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [bifpn0_1_7_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_7_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block4c_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [box-1-bn-6/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block1a_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,039 [WARNING] root: Checkpoint is missing variable [block2b_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [block4c_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [block5c_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [box-1-bn-3/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_2/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [class-1-bn-3/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [class-1-bn-3/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [block4c_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [block6a_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [block6b_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_2_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [class-0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [block5c_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [class-2-bn-3/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [box-2-bn-6/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,040 [WARNING] root: Checkpoint is missing variable [block3a_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [class-1-bn-4/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [block5a_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [block6b_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [class-0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [box-1-bn-3/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [box-predict/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [block4b_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [block3a_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [block4c_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn0_0_8_0/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_1_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [block5b_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_1/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,041 [WARNING] root: Checkpoint is missing variable [box-0-bn-6/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block6a_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [box-1-bn-4/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block6a_project_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block3b_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [weighted_fusion_5_2/weighted_fusion_5_2/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_1/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block5a_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block5b_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block6a_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block6c_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block6c_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [p6_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_4_2/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [bifpn_bn_3_0/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block5a_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block5b_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block6b_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [weighted_fusion_6_1/weighted_fusion_6_1/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [box-1-bn-7/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [box-predict/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block5a_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [class-1-bn-4/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,042 [WARNING] root: Checkpoint is missing variable [block6b_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block6c_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block6d_expand_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block7a_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_3_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block3a_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [box-2-bn-7/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block5c_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block6d_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block6d_project_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [class-0-bn-4/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [class-1-bn-6/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [class-2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [class-2-bn-6/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [stem_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block1a_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block5a_expand_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [block6b_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [p6/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_0/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,043 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [bifpn_bn_7_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [class-1/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block3a_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block3b_expand_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block1a_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block3b_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block6d_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [bifpn0_1_9_0_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [box-0-bn-6/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [class-1-bn-7/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [class-2-bn-4/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block6b_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [bifpn_bn_5_0/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_2/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block4a_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block5c_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [bifpn_bn_0_1/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [class-1/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [box-2-bn-5/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block5b_project_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [class-1-bn-7/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_0/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [bifpn_bn_2_1/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block2a_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block3a_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,044 [WARNING] root: Checkpoint is missing variable [block4a_project_conv/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block4b_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block6b_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_5_2/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [class-1-bn-3/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [box-1-bn-4/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [box-2-bn-3/moving_mean/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [bifpn0_0_8_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block1a_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block2a_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block2a_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block3a_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block3b_bn/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block5c_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block6d_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block7a_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_0_0/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [box-1-bn-5/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block7a_bn/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [bifpn0_2_10_0/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [after_combine_dw_conv_6_0/pointwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [weighted_fusion_1_0/weighted_fusion_1_0/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block5b_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block6a_dwconv/depthwise_kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [block6c_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_2/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,045 [WARNING] root: Checkpoint is missing variable [class-0-bn-3/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [box-0-bn-7/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [class-2-bn-5/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [class-1-bn-5/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [box-1-bn-5/moving_variance/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block2b_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block4a_project_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block4b_expand_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block5b_se_expand/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block5c_se_reduce/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block6d_se_reduce/bias/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block7a_se_expand/kernel/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [p6_bn/beta/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [bifpn_bn_4_2/gamma/ExponentialMovingAverage]
2022-06-29 15:58:17,046 [WARNING] root: Checkpoint is missing variable [block6c_bn/moving_mean/ExponentialMovingAverage]
2022-06-29 15:59:05,512 [INFO] root: Saving checkpoints for 0 into /workspace/tao-experiments/efficientdet/experiment_dir_retrain/model.step-0.tlt.
[GPU 00] Restoring pretrained weights (676 Tensors)
2022-06-29 15:59:09,033 [INFO] root: Pretrained weights loaded with success...
