Issues Running TensorRT Inference on Jetson Orin: CUDA Stream Capture Errors
Hi everyone,
I’m encountering a series of CUDA errors during inference using NVIDIA Holoscan.
The error logs include:
[error] [utils.hpp:63] IExecutionContext::enqueueV3: Error Code 1: Myelin ([cask.cpp:exec:1306] Platform (Cuda) error)
[error] [gxf_wrapper.cpp:118] Exception occurred for operator: ‘holoviz’ - CUDA driver error 906 (CUDA_ERROR_STREAM_CAPTURE_IMPLICIT): operation would make the legacy stream depend on a capturing blocking stream
[error] [infer_utils.cpp:31] Cuda runtime error, operation failed due to a previous error during capture
[error] [entity_executor.cpp:596] Failed to tick codelet holoviz in entity: holoviz code: GXF_FAILURE
[error] [holoinfer_constants.hpp:83] Inference manager, Error in inference execution: Cuda runtime error: cudaErrorStreamCaptureInvalidated, operation failed due to a previous error during capture
[error] [gxf_wrapper.cpp:118] Exception occurred for operator: ‘classification’ - Error in Inference Operator, Sub-module->Compute, Inference execution, Message->Error in Inference Operator, Sub-module->Compute, Inference execution, Inference manager, Error in inference execution: Cuda runtime error: cudaErrorStreamCaptureInvalidated, operation failed due to a previous error during capture
[error] [entity_executor.cpp:596] Failed to tick codelet classification in entity: classification code: GXF_FAILURE
[warning] [event_based_scheduler.cpp:329] Error while executing entity E155 named ‘classification’: GXF_FAILURE
[info] [event_based_scheduler.cpp:671] Stopping all async jobs
when running the test again, the error often changes :
[error] [utils.hpp:63] IExecutionContext::enqueueV3: Error Code 1: Cask (Cask convolution execution)
[error] [gxf_wrapper.cpp:118] Exception occurred for operator: ‘holoviz’ - [/workspace/holoscan-sdk/modules/holoviz/src/vulkan/resource.cpp:69] CUDA driver error 906 (CUDA_ERROR_STREAM_CAPTURE_IMPLICIT): operation would make the legacy stream depend on a capturing blocking stream
or
[error] [utils.hpp:63] IExecutionContext::enqueueV3: Error Code 1: Myelin ([direct.cpp:exec:136] ‘__mye52244’: wait failed (1))
From what I understand, the CUDA error 906 (CUDA_ERROR_STREAM_CAPTURE_IMPLICIT) and cudaErrorStreamCaptureInvalidated relate to issues with CUDA stream capture and legacy stream dependencies. However, I’m not sure exactly what causes this in my code and how to fix it.
The first inference of the classification with Holoinfer is going well, and I had no issue during the conversion onnx to engine with trtexec .
Environnment :
  • JetPack 6.0
  • jtop 4.2.8
  • CUDA 12.6.20
  • TensorRT: 10.3.0
  • ONNX model : mvit (classification)
  • Running on Jetson Orin (nvgpu) ARM64
Thanks in advance for any pointers or solutions!
this seems to be an issue with CUDA Graphs. Could you try setting the enable_cuda_graphs parameter of the inference operator to false?
The inference works for the first iteration because CUDA Graph usage is only enabled for the second and later iterations.
There are some limitation when using CUDA Graphs with TensorRT, see Best Practices — NVIDIA TensorRT Documentation for more information.
Regards,
Andreas
