Hi all,
I am currently having a similar issue to the one on this post. I am trying to connect 16 cameras using the D3 expansion board.
The error seems to be related to Argus. I am able to capture from v4l2-ctl but I cannot from GStreamer nvarguscamerasrc. The error is the following:
nvidia@linux:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=8 ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:645 No cameras available
(gst-launch-1.0:15432): GStreamer-CRITICAL **: 11:25:49.959: gst_mini_object_set_qdata: assertion 'object != NULL' failed
Got EOS from element "pipeline0".
Execution ended after 0:00:00.337293761
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
So far, I have tried some configurations which are:
- Connecting one camera: when connecting the camera in any port from 0 to 7, all seems to work. From 8 to 15, I cannot capture.
- Connecting multiple cameras in ports from 0 to 7 works as well. From 8 to 15, it does not work.
- When I connect some cameras to ports 0 to 7 and other ones to ports 8 to 15, I can capture from none of them.
This issue appears after trying to upgrade from Jetpack 4.4 to Jetpack 4.5.1. In the former version, it worked fine, but the upgrade crashed. I saw that @diego.chaverri had a similar issue to this one (I would say the same issue). Is it possible to get the binaries or a fix for the Jetson Xavier AGX (Jetpack 4.5.1)?
Please, if you need more information, let me know.
Best regards,
