Hi all,
during loading of a texture which size is equal to / bigger than 2.4GB I encountered an error:
“Unknown error (Details: Function “_rtContextLaunch2D” caught exception: Assertion failed: “!m_enteredFromAPI : Memory manager already entered from API”, file: C:\u\workspace\rel5.1-win64-cuda90-VS2015-build-Release\sw\wsapps\raytracing\rtsdk\rel5.1\src\Memory\MemoryManager.cpp, line: 963)”
You should be able to easily reproduce this by loading an .ppm file bigger than 2.4 gigs (mine was a 24576 by 24576 texture with 4 unsigned byte channels) in the optix advanced sample 07 ([url]https://github.com/nvpro-samples/optix_advanced_samples/tree/master/src/optixIntroduction/optixIntro_07[/url])
I use a GeForce GTX 980M with 4GB RAM which should be capable of handling this size of texture (I guess) during this small example…
If you have any idea where I maybe missed some point or how I can track down what exactly is going here, please let me know. (USE_DEBUG_EXCEPTIONS activated didn’t help.)
EDIT: Is there maybe any known issue as this size exceeds INT_MAX?
Thanks in advance!
