This is my curand_m interface file:
module curand_m
integer , public :: CURAND_RNG_PSEUDO_DEFAULT = 100
integer , public :: CURAND_RNG_PSEUDO_XORWOW = 101
integer , public :: CURAND_RNG_QUASI_DEFAULT = 200
integer , public :: CURAND_RNG_QUASI_SOBOL32 = 201
interface curandCreateGenerator
subroutine curandCreateGenerator(generator,rng_type) &
bind(C,name='curandCreateGenerator')
use iso_c_binding
integer(c_size_t ):: generator
integer(c_int),value :: rng_type
end subroutine curandCreateGenerator
end interface curandCreateGenerator
interface curandSetPseudoRandomGeneratorSeed
subroutine curandSetPseudoRandomGeneratorSeed(generator,seed) &
bind(C,name='curandSetPseudoRandomGeneratorSeed ')
use iso_c_binding
integer(c_size_t), value :: generator
integer(c_long_long),value :: seed
end subroutine curandSetPseudoRandomGeneratorSeed
end interface curandSetPseudoRandomGeneratorSeed
interface curandGenerateUniform
subroutine curandGenerateUniform( generator , odata , numele) &
bind(C,name='curandGenerateUniform ')
use iso_c_binding
integer(c_size_t),value :: generator
!pgi$ ignore_tr odata
real(c_float), device::odata(*)
integer(c_size_t),value :: numele
end subroutine curandGenerateUniform
subroutine curandGenerateUniformDouble(generator,odata,numele) &
bind(C,name='curandGenerateUniformDouble')
use iso_c_binding
real(c_double), device :: odata(*)
end subroutine curandGenerateUniformDouble
end interface curandGenerateUniform
interface curandGenerateNormal
subroutine curandGenerateNormal(generator,odata,numele,mean, &
stddev) &
bind(C,name='curandGenerateNormal ')
use iso_c_binding
real(c_float), device :: odata
real(c_float), value :: mean ,stddev
end subroutine curandGenerateNormal
subroutine curandGenerateNormalDouble(&
generator , odata , numele ,mean , stddev) &
bind(C,name='curandGenerateNormalDouble ')
use iso_c_binding
real(c_double), value :: mean ,stddev
end subroutine curandGenerateNormalDouble
end interface curandGenerateNormal
interface curandDestroyGenerator
subroutine curandDestroyGenerator(generator) &
bind(C,name='curandDestroyGenerator ')
use iso_c_binding
end subroutine curandDestroyGenerator
end interface curandDestroyGenerator
end module curand_m
and this is part of main program:
!$cuf kernel do <<<*,*>>>
do i = 1 , nwalk
call curandCreateGenerator(gen , CURAND_RNG_PSEUDO_DEFAULT )
call curandCreateGenerator(gen1 , CURAND_RNG_PSEUDO_DEFAULT )
seed = set_seed()
call curandSetPseudoRandomGeneratorSeed ( gen , seed)
call curandSetPseudoRandomGeneratorSeed ( gen1 , seed)
call curandGenerate(gen , d_temp , 2)
call curandGenerateUniform(gen1 , d_epsilon , 2)
This is the compile time error I get :
PGF90-F-0000-Internal compiler error. Unsupported procedure 0 (hgen_test_kernel.CUF: 305)
PGF90/x86-64 Linux 12.10-0: compilation aborted
pseudo_test.CUF:
PGF90-S-0155-Could not resolve generic procedure curandgenerateuniform (pseudo_test.CUF: 81)
0 inform, 0 warnings, 1 severes, 0 fatal for pseudo_test
The first error pops in because the necessary random generations are not made which is needed by the global device function.
Any Ideas on how to solve this issue are welcomed.
Also I will like to ask since I’m a bit new with CUDA if nested device function calls by global device code is allowed in CUDA version 4.2?
