Context: I’m trying to do some pseudorandom number generation at the GPU using CURAND, but since I’m using CUDA fortran I have to create an interface module, which interfaces the CURAND LIBRARY functions written in C. Here is the interface code:
interface curand_init
attributes(device) subroutine curand_init(seed,sequence,offset,state) &
bind(C,name='curand_init')
use iso_c_binding
integer(c_long_long),value :: seed
integer(c_long_long),value :: sequence
integer(c_long_long),value :: offset
!pgi$ ignore_tr state
real(c_float), device :: state(*)
end subroutine curand_init
end interface curand_init
interface curand
attributes(device) subroutine curand(state) &
bind(C,name='curand')
use iso_c_binding
real(c_float),device :: state(*)
interface curand_uniform
attributes(device) subroutine curand_uniform(state) &
bind(C,name='curand_uniform')
use iso_c_binding
end subroutine curand_uniform
attributes(device) subroutine curand_uniform_double(state) &
bind(C,name='curand_uniform_double')
use iso_c_binding
real(c_double),device :: state(*)
end subroutine curand_uniform_double
end interface curand_uniform
interface curand_normal
attributes(device) subroutine curand_normal(state) &
bind(C,name='curand_normal')
use iso_c_binding
end subroutine curand_normal
attributes(device) subroutine curand_normal_double(state) &
bind(C,name='curand_normal_double')
use iso_c_binding
end subroutine curand_normal_double
end interface curand_normal
in the same module I make a call to this device subroutine call
curand_init(seed,id,0,tmpconf)
in a global kernel. I get this error when I call the global kernel.
gpu_gen_m.CUF:
PGF90-S-0155-Could not resolve generic procedure curand_init (gpu_gen_m.CUF: 99)
0 inform, 0 warnings, 1 severes, 0 fatal for gen_conf
gpu_gen_m.CUF:
any Idea how I can resolve this issue?
