Issues with Disaster Risk Monitoring Using Satellite Imagery course
Hi
I am having issues with the Disaster Risk Monitoring Using Satellite Imagery. Is something out of date with the course?
I have an NVIDIA NGC API Key and the introduction works fine when I login.
When I run the dockers container for training a deep learning model I keep getting this error:
Pulling from repository: nvcr.io/nvidia/tao/tao-toolkit-tf Docker pull failed. 404 Client Error: Not Found (“pull access denied for nvcr.io/nvidia/tao/tao-toolkit-tf, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied”)
Any thoughts? Thanks.
Hello and welcome to the forums.
This issue will require someone from the DLI team to investigate.
An engineer will reach out ASAP.
Thanks for you patience,
Tom
Same issue here, still not fixed
hello, thanks for reporting this issue. the old TAO toolkit was attempting to pull a container that no longer exists and is deprecated. i have updated the course to pull the correct docker containers.
