Still the same behaviour on all our machines and no idea what causes the problem. When does the stable version of CUDA Toolkit 2 gets released? Hopefully we can use the new cards then?!
Regards,
Manuel
Regards,
Manuel
I am getting some freezes also with Windows XP Professional 64 Bit, 177.35 driver, Cuda SDK 2.0 beta. Hardware is nVidia 8800GT
The Mandelbrot demo stops updating its display window, although the window title still updates the FPS numbers. This occurs randomly, after some seconds of zooming and panning in the fractal.
Christian
We have the same problems with linux (Asus GTX280, 32bit linux, 177. 13 driver, cuda 2.0beta) and the mandelbrot example, all other examples work fine.
We did some tests with the currently released display driver (177.41) within windows (32bit) and encountered much more stable applications. Mandelbrot does still lock up the computer but still our programs seem to work with the new drivers. Just for everybody having problems → try the current windows release of the display drivers and report if the problems are gone or not.
As our development is mostly done on Linux we are very keen on seeing an updated and more stable version for the display driver there. At best for Ubuntu 8.04 ;-). So enough for the wishlist and we hope that our work can finally be tested on the new cards.
Regards,
Manuel
Ah yes one last question: Why is the display driver version not consistent on the different sites? www.nvidia.com gives for Win XP the 177.41 and on developer.nvidia.com the 177.35 is suggested.
We installed the new drivers and cuda 2.0 and everything seams to be ok now. At least our programs are running stable with the new toolkit. I did not test the Mandelbrot example but i’m more interested in seeing our programs work…
Manuel
I’m curious to know what has come of these issues since you last posted. Did the new drivers and cuda 2.0 fixed these problems for everyone or not?
I am having similar problems with a GTX280 in 32-bit LINUX using driver 177.67 and CUDA 2.0
X will lock up with some of my programs and with the Mandelbrot example. Before locking up, the CPU % that xorg is using goes crazy.
I’ve also had similar issues with a similar setup (same card and drivers in linux).
Are these stock clocked GTX 280s? I haven’t seen any problems on my setup, so I’m not sure what’s going on.
I replied to your question in another thread, but in the interest of someone finding this thread in the future (and not the other one), I’ll answer it here too.
Our GTX 280 is by EVGA and is running at the standard clock rate. 602 MHz I believe it is …
My GTX 280 is from ASUS and I haven’t changed any card-specific settings.
We are using a EVGA Card without any change in the clock rate.
Regards,
Manuel
Using a standard BFG GTX 280, Vista x64 and the most recent CUDA sdk/drivers, the Mandelbrot example freezes here also (though the frame rate still updates). I haven’t had any problems with any of the other examples. Perhaps the Mandelbrot example is just messed up on the newer architectures - switching to hardware double precision doesn’t seem to work either.
