I’ve got a big problem, I can’t install ubuntu and some Ubuntu-based Linux distro but Pop Os on my laptop. Let me illustrate the problem, I’ve tried elementary os, ubuntu, Feren os, KDE neon, Zorin os,… and after they get installed and I restart to enter os environment, they don’t boot to Os environment. I have not this problem with Pop os. I recently bought the laptop and I am so disappointed about that, I will be so happy if you help to fix the problem. (I don’t use dual-boot by the way) Ubuntu version is 20.04.2 and others are based on the LTS version (Desktop version) The current Linux distro on my machine is pop os 20.04.2 which works perfectly nice if you wanna take a look at my laptop specs
Since PopOS is also based on Ubuntu 20.04, there should be no problem running that. The only requirement is to choose the HWE kernel since the amd gpu requires kernel 5.6 minimum.
This may sound dumb, but check your laptop’s bios. I had a similar sounding problem with an Asus Zenbook 14. The boot sequence was locked and I had to enter a code (easily obtained) to unlock it to allow booting by USB.
