Hi - current POP OS is using nvidia driver 460.56
- which is not the one currently supported by the omniverse linux beta - is this why create will not launch?
Hope this will change soon
Neil
Neil
Hi Neil, that is likely to be one reason that it’s not working.
Here’s something you can try:
This will skip driver verification, but will try and load Create anyway. You may encounter bugs/crashes/instability with an unsupported driver, but at least it will help us understand if that is the only problem.
Eoin
Hi Eoin
That worked! I can run it - and yes its slow a bit… but works.
Great, does that mean as its developed hopefully I can just eventually see the nvidia drivers align…and then I can run it from the launcher… I see that POP OS linux is using the latest nvidia drivers for Linux… currently.
Thank you for the help
Neil
Hi Neil,
yes - we update supported driver versions fairly regularly…
Eoin
Excellent - thankyou
